Results 1 to 3 of 3
Thread: Script help!
    Junior Member speedygoss's Avatar
    Mar 2009
    Default Script help!
    So from what I understand I can convert a tune from one O/S to mine by creating a script. I have found a step by step tutorial on this.
    http://www.thetruckstop.us/forum/showthread.php?t=19257
    I have followed the steps and when I attempt to load the alternate calibration a warning pops up that basically says that the two operating systems do not match and No comparison will be attempted... Any help would be appreciated.
    P.S. The two tunes I'm working with are both for an LLY just a differant O/S
    Feb 2011
    Can you make your script first by running the same OS on both to make it?
    I'm wondering if you can make a script on the regular OS between stock ECM and the Tune file, then go into a DSP5 OS and utilize that script??
    Jan 2006
    Eric, you will need a "stock" tune opened first, and the "modified" tune opened for comparision. Must be same OS. Create script. That creates the changes to make.
    In a new window, open the new OS "stock" file.
    If you need a stock file of the new OS, email me.
    Custom Tuning Services
  1. LBz to LMM script
    By terryr85 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 7th, 2010, 02:04 AM
  2. creating a script
    By SGFastMax in forum Duramax LB7
    Last Post: June 10th, 2009, 08:26 AM
  3. Script ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2009, 06:46 PM
  4. The new script feature
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2008, 11:36 AM
  5. Script help
    Last Post: February 27th, 2006, 03:07 PM
