Results 1 to 10 of 10
Thread: Faster Tap Shift Response
    Mar 2007
    Default Faster Tap Shift Response
    Just wondering if their would be a way to speed up the tapshifting up or down through the programming. Mine seems a little lazy. It is esp true if it has a load on it. Sometimes I think I even hit it twice before it does anything. It was kinda nice on the older gen, you move the lever and you have instant down shift.
    Jan 2008
    mine is pretty quick even with a load. maybe you have a bad button?
    Mar 2007
    nope, I have a LMM..... I have compared to other LMM's and LBZ's. The LBZ's react a lot faster...esp when pulling the sled. It seems as though there is a 1 sec delay... I would like to get rid of. I may log it, I think you can see commanded gear vs when it shifts.
    Jan 2008
    yeah you should be able to.
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    no, if you look in the TCM tune you'll clearly see there is no table that refers to this..
    and Id bet my truck on the fact that figuring out the switch debounce and delay programming is nowhere near the top of efilive's priority list.
    ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Quote Originally Posted by DURAtotheMAX View Post
    ben
    If it's even possible... I'm pretty sure the T43 guys have been complaining about the tap-shift delays on their transmissions for some time, but I don't think it's been figured out either.
    Nov 2005
    its probably something in the base firmware, not the calibration, or maybe there is even 'hardware' de-bounce circuitry in the shifter itself, like a capacitor or something.
    12.9s @ 108 mph
    Feb 2008
    try hitting the switch about a second before you normally would. That should fix it.
    12 Second LMM
    Jan 2008
    Quote Originally Posted by duramaximizer View Post
    Quote Originally Posted by bballer182 View Post
    ben
    My reply was in reference to the logging selected gear vs. current gear.
    Mar 2007
    ben
    No shit shurlok. It's a pipe dream just like you being able to lock your converter on time. Lay off. It was a request.
    On EDIT: Thanks Mike....... ya just right ....shit too late.
  1. How to scan speeds faster than 158 mi/h (255km/h)?
    By Treurentner in forum Petrol / Gas
    Last Post: February 22nd, 2018, 12:58 PM
  2. Faster Free Rev?
    By Wasted Income in forum Gen III V8 Specific
    Last Post: April 26th, 2010, 01:51 PM
  3. I need a custom OS to make my M6 shift faster
    By Highlander in forum Custom Operating Systems
    Last Post: January 10th, 2010, 11:40 AM
