Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 185
Thread: Tuning Notes by WeathermanShawn
    Jul 2008
    Default Tuning Notes by WeathermanShawn
    Here is a description of the CALC.VE method of Tuning.
    I originally followed the current method of disabling the MAF and mapping my VE Table using the wideband and AFR BEN's as described in the Tutorials. I then followed the protocol of then 'calibrating' the MAF. I found the procedure of mapping the VE Table with disabling the MAF a little tedious, but in the end it was successful. However, once I enabled the MAF..I ran into trouble. It was a long and tedious procedure to match the SD Airflow. And went I went back to closed-loop..it was a lot of work to then get LTFT's to match up.
    For those who run MAF and closed-loop, I have the following method to propose. First MAP MAF Frequency against your LTFT's. Apply the same filters that are normally suggested when you construct a VE Table. Then simply cut and paste the correction to the MAF Calibration Table found in your Tune. I then used the following EFILive Pid: CALC.VE.
    Volumetric Efficiency {CALC.VE}:
    % = {SAE.MAF.gps}*({SAE.IAT.C}+273.15)/((displacement()*61.024)*{SAE.RPM}*{SAE.MAP.kPa})* 212544
    It is basically utilizing the MAF Airflow along with your RPM's and MAP. It also utilizes the IAT, and in the end utilizing a RPM vs MAP..you can easily construct a VE Table..just from the MAF output.
    You must utilize a wideband! This is to verify that your narrow-band O2's are switching properly and maintaining stoich. Also, you must be commanding the proper AFR at WOT. It actually matches up fairly well to the original VE Table (SD method).
    Feel free to add any comments, constructive criticism, or comments.
    Nov 2006
    100% MAF first w/LTFTs then VE w/CALC.VE, or is VE changed the same time as MAF?
    How are LTFTs applied, do you have a calc_pid?
    Did you change the O2 switch points before using LTFTs?
    Its fun to try to hit those high MAP areas @ mile high isn't it.
    At most I am able to hit 90kPa but only when I go down hill.
    LC-1 WBO2
    Jul 2008
    Yea, I am drastically limited by altitude! I can only hit ~ 82-84 kPa on a good day.I
    I somehow settled on a O2 switch-point of 550 mv. Maybe just the way my car responded. But, it does give me stoich (wideband logged) when I MAP it.
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Great read, thanks! My baseline barrometric pressure around here is ~85-86kpa, on a very rare day I could hit 90 for maybe 1-2 cell counts. now that I have the blower I can break through that barrier, but I saw a significant drop in power when I moved from ~500 ft to ~4500 ft.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Oct 2006
    Shawn, I believe that you must also calculate the IAT/ECT blending factor into your pid to get it closer. I will add something to try as soon as it quietens down here.
    The Tremor at AIR
    Oct 2006
    Something like this.
    CALC.BLEND ="lookup({SAE.MAF}, 0.00,0.799805, 10.00,0.419922, 20.00,0.282715, 30.00,0.243652, 40.00,0.219727, 50.00,0.202637, 60.00,0.188477, 70.00,0.175781, 80.00,0.164551, 90.00,0.153809, 100.00,0.143555, 110.00,0.134277, 120.00,0.124512, 130.00,0.115234, 140.00,0.106445, 150.00,0.089844)"
    % = {SAE.MAF.gps}*({SAE.IAT.C}+(({SAE.ECT}-{SAE.IAT})*{CALC.BLEND})+273.15)/((displacement()*61.024)*{SAE.RPM}*{SAE.MAP.kPa})* 212544
    The Tremor at AIR
    Nov 2006
    Ok.
    After MAF is done w/LTFT, then VE is molded w/calc_ve via straight paste.
    LC-1 WBO2
    Jul 2008
    Ok.
    Perfectly stated! Do you think it has some validity?
    Oct 2006
    It certainly has some validity. It would be interesting to compare the resultant AFR's going straight from maf to SD, after the VE table has been calculated in this manner.
    The Tremor at AIR
    Jul 2005
    ok, i'm gonna be a science stickler again...
    check your units, what does g*K/(sec*m^3*kPa) simplify to?
    you do know that IAT != MAT and that cylinder airmass from MAF is already done for you in the form of CYLAIR, right? so then to solve for VE, all you need to do is start with CYLAIR=VOL*VE*MAP/(R*MAT), and rearrange to isolate VE so you end up in the form of
    VE=CYLAIR*R*MAT/(VOL*MAP)
    if you want dimensional analysis of it done, it's a bit convoluted, but it checks out clean. it's all in my 'how SD works' from four years ago.
  1. New Tuning Tutorial: WeathermanShawn
    By WeathermanShawn in forum Tutorials
    Last Post: March 1st, 2011, 09:31 AM
  2. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  3. Release notes
    By PSWired in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 03:40 AM
  4. Beta Releases and Log Files Full Of Notes
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2008, 10:10 PM
  5. User Notes
    By Lextech in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2007, 12:57 PM
