Results 1 to 1 of 1
Thread: 0 Degrees when Cranking?
    Apr 2008
    Default 0 Degrees when Cranking?
    I am trying to log timing when cranking, but am not having any luck. EST_Crank_DMA does not show any data when logging. I am having a hard start issue and have tried adjusting B5909, but no luck. Has anyone seen an issue like this?
    Seems like I am reading 0 degrees when cranking when using a timing light.
    S10TEST.tun
    START2.efi
    383 internal balance L31 Vortec
    Mercruiser MPFI ported, 27lb injectors, ported throttle body
    Iron 64cc vortec ported and polished
    Comp Cams Beehive springs for 0.550 lift, Crane gold rockers 1.5 Camshaft:Comp Cams XFI 280 hydraulic roller, Comp Cams Magnum hydraulic rollers
    Cam specs:
    Operating Range: 2000-6000 RPM
    Duration Advertised: 280° Intake / 288° Exhaust
    Duration @ .050'' Lift: 230° Intake / 236° Exhaust
    Valve Lift w/1.6 Rockers: .576'' Intake / .570'' Exhaust
    Lobe Separation Angle: 113°
  1. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 08:36 PM
  2. Why always 10 Degrees at WOT
    By 1bar in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 6th, 2009, 01:56 PM
  3. b7934 degrees
    By dynarex in forum Gen IV V8 Specific
    Last Post: February 17th, 2008, 03:30 PM
  4. Can you go from C to F degrees?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 12:12 AM
  5. Run Spark 50 degrees?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 01:00 AM
