Last edited by WeathermanShawn; February 9th, 2010 at 10:16 AM. Reason: Redundant..
i tried playing with the BARO settings, no matter what i did always updated to 105kpa, didnt seem to affect fueling so i thought it was for diagnostic purposes (this is while using MAF), finally got my 2bar map sensor in but ran out of decent weather/gas money to put it into S.D. and COS5, gonna give it a try when the roads dont have so much gravel on them (garage queen car). up I70w in the summer....damn you're a glutton for punishment...lol air should be pretty crappy here then (9000+ D.A. in the city)
2002 SS, PROCHARGER AND SOME OTHER GOODIES
Thanks again for so much effort in writing all this up! Here's a log I took with my stock to-the-air filter 2005 Tahoe 4.8L. Its wifey's truck for my twin boys (1 years old!). Can you take a look if the map is setup correct? I want to take a longer cruise tonight if I can slip away. I'm REALLY excited about your process. I'll have to take my LM1 from my WS6 this weekend.
Yea, from what I can see you have everything set-up and done properly. Obviously some of the RPM/MAP boundaries will always be a little more of a challenge..very little MAF flow and if you start stalling, etc., you will get some erroneous readings.
Sometimes it is 'fun' to display your VE Table in g/s vs % of Theoretical Maximum. Then do a MAP with your MAF Flow (g/s) using the same RPM/MAP boundary. I say that because sometimes at very little MAF flow small differences can make a % difference a little misleading. But, you are doing everything right..
Let us know how it goes. I am hoping at least people can utilize the technique initially, then go more advanced if they so desire.
Shawn,
I really like what you have done to date and I plan to play around with this concept myself.
Good Job!
Steve
Last edited by WeathermanShawn; February 9th, 2010 at 10:18 AM. Reason: Not Applicable..
Here is the calc_pids for average LTFT and LTFTBEN from both banks
You use LTFTBEN the same as BEN. (paste & multiply)
calc_pids.txt
LC-1 WBO2
Shawn,
Great work. This update is easier to understand. Keep it up!
Thanks.
Last edited by WeathermanShawn; February 9th, 2010 at 10:17 AM. Reason: Redundant, Not Applicable..
