Originally Posted by
Mr. P.
THAT'S NOT ENOUGH -
You need to make sure the fans ALSO come on when the A/C compressor is running, or else you will overheat the freon and it will be safety-vented to the atmosphere.
Pin 42 only grounds when the ECT is above your programmed setpoint; it will not turn the fans on when the A/C is running; this was changed in the 2003+ PCM's and climate control systems, those PCMs and OSs *will* turn the fans on based on A/C system pressure, but your hardware won't.
Mr. P.
