Results 1 to 10 of 10
Thread: Do I need a new ECM and TCM?
    Jan 2010
    Default Do I need a new ECM and TCM?
    After countless tries of attempting to read the tcm and ecm stock tune on my 06 LBZ, I kept getting the same result saying that efi cannot recgonize the tcm or the ecm and ultimately says calibration missing. Do I need a new ecm and tcm or is something wrong with the efi v2 flash scan controller? Thanks in advance.
    LBZ/LMM Allison TCM
    Scanning for EFILive FlashScan V2 USB
    21:45:18.312: Autodetect interface ...
    21:45:18.500: Interface firmware version: 2.4.38
    21:45:18.500: Connection to [FS2] interface is OK
    21:45:18.546: Interface firmware model: FS2
    21:45:18.562: Interface firmware version: 2.4.38
    21:45:18.578: Interface firmware date: Nov 08, 2006
    21:45:18.609: FlashScan serial number: 003589640202
    21:45:18.625: FlashScan license number: 003589640202
    21:45:18.640: Disconnecting ...
    21:45:18.703: Disconnected
    21:45:19.390: Scanning for EFILive FlashScan V2 USB
    21:45:19.406: Autodetect interface ...
    21:45:19.593: Interface firmware version: 2.4.38
    21:45:19.593: Connection to [FS2] interface is OK
    21:45:19.625: Current protocol set to: "ISO 15765 CAN"
    21:45:19.625: Autodetect PCM...
    21:45:21.656: PCM not detected.
    21:45:21.656: Autodetect ECM...
    21:45:23.687: ECM not detected.
    21:45:23.687: Autodetect TCM...
    21:45:25.718: TCM not detected.
    21:45:25.750: Interface firmware model: FS2
    21:45:25.765: Interface firmware version: 2.4.38
    21:45:25.796: Interface firmware date: Nov 08, 2006
    21:45:25.812: FlashScan serial number: 003589640202
    21:45:25.843: FlashScan license number: 003589640202
    21:45:25.859: Getting status...
    21:45:27.125: Status: Calibration missing.
    21:45:35.578: Request GM VIN...
    21:45:37.625: Autodetect interface ...
    21:45:37.703: Interface firmware version: 2.4.38
    21:45:37.703: Connection to [FS2] interface is OK
    21:45:37.703: Autodetect TCM...
    21:45:39.734: TCM not detected.
    21:45:40.750: VIN: 003589640202
    21:45:41.718: Preparing TCM for reading flash...
    21:45:43.765: Autodetect interface ...
    21:45:43.843: Interface firmware version: 2.4.38
    21:45:43.843: Connection to [FS2] interface is OK
    21:45:43.843: Autodetect TCM...
    21:45:45.875: TCM not detected.
    21:45:46.890: TCM may not be secured - did not reply to seed request
    21:45:46.890: Initializing TCM...
    21:45:55.093: Total time: 00:08
    21:45:55.109: Rebooting TCM... (please wait up to 8 seconds)
    21:45:57.546: Disconnecting ...
    21:45:57.593: Disconnected
    21:46:02.968: Done!
    LBZ Duramax Diesel ECM
    21:49:27.906: Scanning for EFILive FlashScan V2 USB
    21:49:27.921: Autodetect interface ...
    21:49:28.109: Interface firmware version: 2.4.38
    21:49:28.109: Connection to [FS2] interface is OK
    21:49:28.140: Interface firmware model: FS2
    21:49:28.171: Interface firmware version: 2.4.38
    21:49:28.187: Interface firmware date: Jan 01, 2000
    21:49:28.203: FlashScan serial number: 003589640202
    21:49:28.234: FlashScan license number: 003589640202
    21:49:28.250: Disconnecting ...
    21:49:28.296: Disconnected
    21:49:28.968: Scanning for EFILive FlashScan V2 USB
    21:49:28.984: Autodetect interface ...
    21:49:29.171: Interface firmware version: 2.4.38
    21:49:29.171: Connection to [FS2] interface is OK
    21:49:29.187: Current protocol set to: "ISO 15765 CAN"
    21:49:29.187: Autodetect PCM...
    21:49:31.218: PCM not detected.
    21:49:31.218: Autodetect ECM...
    21:49:33.250: ECM not detected.
    21:49:33.250: Autodetect TCM...
    21:49:35.281: TCM not detected.
    21:49:35.312: Interface firmware model: FS2
    21:49:35.343: Interface firmware version: 2.4.38
    21:49:35.359: Interface firmware date: Nov 08, 2006
    21:49:35.375: FlashScan serial number: 003589640202
    21:49:35.390: FlashScan license number: 003589640202
    21:49:35.421: Getting status...
    21:49:36.500: Status: Calibration missing.
    21:49:41.234: Request GM VIN...
    21:49:43.281: Autodetect interface ...
    21:49:43.359: Interface firmware version: 2.4.38
    21:49:43.359: Connection to [FS2] interface is OK
    21:49:43.359: Autodetect ECM...
    21:49:45.390: ECM not detected.
    21:49:46.406: VIN: 003589640202
    21:49:47.359: Preparing ECM for reading flash...
    21:49:49.406: Autodetect interface ...
    21:49:49.484: Interface firmware version: 2.4.38
    21:49:49.484: Connection to [FS2] interface is OK
    21:49:49.484: Autodetect ECM...
    21:49:51.515: ECM not detected.
    21:49:52.531: ECM may not be secured - did not reply to seed request
    21:49:52.531: Initializing ECM...
    21:50:00.734: Total time: 00:08
    21:50:00.750: Rebooting ECM... (please wait up to 8 seconds)
    21:50:03.187: Disconnecting ...
    21:50:03.234: Disconnected
    21:50:08.734: Done!
    Smitty, you are getting some odd data there, but I can also see the firmware is very old on your V2, I guess the software might be as well?
    Have you had this thing stored away for 2 years or something?
    Im with Ross, I havent seen a firmware or bootblock that old in at least a year.
    Download the latest V7.5.6 build 104 AND 8.1.2 build 84.
    See this link: EFILive Latest Update
    Install both downloads, then update your bootblock FIRST then do the firmware upgrade otherwise you will brick you V2.
    Then try the reflash again, most likely it will work as I havent seen any LBZ reflash issues in a while.
    Good point, 2.4.38 is quite old...
    Before updating the V2 bootblock/firmware please read the attached document carefully, make sure you understand all of it before proceeding.
    Jan 2010
    Oh this all makes sense now then. No I have not stored any old files for 2 years. I just bought this new and unopened EFI live v2 flash scan from a guy in Carolina who bought it a couple years ago but never even opened it. I will try this update and hopefully it will work! thanks alot and I will report back.
    Quote Originally Posted by smitty91 View Post
    Yep, not surprised it has an ancient bootblock/firmware then! A TON has changed in the last 6mo, the last 2 years Im not sure anything is the same by now lol.
    Report back if it works, if not Im sure we can get you up and running asap!
    Jan 2010
    Wow thank you so much everyone I finally got it to work. For a second I thought I had been sold a broken unit! Thank you especially joecar, I followed your attachment and it completely fixed the problem. Thanks again this is an awesome forum
    So it works ok on vmWare Fusion...
    Glad you got it working!
    Now that you're up to date, all the minor updates are painless. Just download and install the software and open up EFILive Explorer, it will automatically prompt you to upgrade your firmware!
    Jan 2010
    No unfortunately it is not working on vmware fusion. I am having trouble with it recognizing the device in the usb port for some reason I think there is something wrong with my laptop. I had to use an old pc to perform this task. Thanks again everyone i'm so glad to have this up and running.
