Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: DPF Regen Effectiveness
    Default DPF Regen Effectiveness
    I found out the hard way, that tuning could involve killing the effectiveness of the cycle. I have no idea what I did specifically that hurt it, but it was clear that I was going to run my tune in regen, nearly full time because soot was building up as fast as the regen could remove it. I am pretty sure it was not a dirty tune, but rather, I change SOMETHING that killed regen effectiveness. As soon as I reflashed stock, the soot melted off at 10X rate.
    I started this thread to discuss one thing: Regen criteria for fast effective regenerations.
    If you have some educated ideas on what parameters constitute more effective (hot) regen, then please contribute. I would really like this to be an educational thread for tuners, so that we can all benefit. I wasted at least 40 hours of tuning, and would like to help others not follow in this path.
    Custom Tuning Services
    ok, sleepy crowd.
    Is there an injector at the dpf site?
    Mar 2007
    NO!
    There is no injector. I think 3 sensors pre and post pressure, and EGT.
    My guess is timing is killing it somehow, it is messing with post injection quanity or time.
    Link no worky
    04 LB7
    2010 LMM
    2015 LML
    Does anyone have a regen log they can attach here, one that clearly shows post-injection?
    It is unfortunate that the software has NO dpf tables for timing, fuel pressure, soot limits, EGT modulation, intake valve modulation, etc. Regen is such a critical part of effective operation, especially for those trying to stay legal.
    Is there a chance that we may see some of this?
    Time for you to go and buy GM's tuning software Michael.
    Nov 2005
    Keep your post injections in... If you kill them it will definately reduce your time between regens..
    As a test, drop back to 2 injections.. Drive 20 miles and you're catalyst will be full.. Then turn on the handy dandy scan tool. You can watch soot mass in the DPF fall rather quickly with a 100% clogged filter if you go back to 5 injections.
    I've got some clean 425rwhp tunes running out there with no issues. What problems were you having in particular?
    Quote Originally Posted by Brayden View Post
    I figured as much. I have a learning curve now, and figure that this thread might serve to help others not make the same mistakes, but also serve as a tech thread on DPF theory. We'd all like for regens to take as little fuel as possible.
    BTW, what is the table number for the number of injection events? I must be losing it, I can't seem to find it now.
    I don't think my wife will approve.
  1. Really need LMM>V2 Regen help asap!
    By Sleepertrk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2008, 01:12 PM
  2. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
  3. manual regen on LMM's
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2007, 05:01 AM
