Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: DPF Regen Effectiveness
  1. #41
    It's pretty tough out here to get to an LMM for testing, the only place that regularly brings them in usually pulls the DPF etc off during the conversion. If we get lucky they will have one there, if not, it could be weeks off, maybe longer before I can't try.
  2. #42
    Mar 2007
    I don't want to, but if I have to, I could put my dpf back on and load the old 7103 OS back in and see if the DVT's work. I haven't played with them at all, I had no reason to.
    2007.5 RCLB 4x4 WT LMM 8594OS
  3. #43
    Update.. Still no DVT regen ability. Normal regen started at 45g, ended at 7.
    I found I got 5g per minute regen when I started at 90g. 2g per minute when it starts at 45g. That tells me a little about how I would LOVE to adjust the regen cycle.
    I also managed to determine that lowering boost helped decrease my regen time by increasing EGT1 about 50F. This is preliminary, subject to further analysis. There is nearly no regen below 900, but this changes exponentially to 1200F.
    Idle regen is possible, and does occur, but fuel consumption is more than double what normal idle is. Fun to see 1100 egt at idle.
    Hope to see more tables that will allow us "compliant" do-gooders play around some more.
    Custom Tuning Services
  4. #44
    shaking the cobwebs off. There are some things happening with flash updates at GM that would be important to get our heads around. There are a lot of regen issues with LMM, that appear to be based in old flash.
  1. Really need LMM>V2 Regen help asap!
    By Sleepertrk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2008, 01:12 PM
  2. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
  3. manual regen on LMM's
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2007, 05:01 AM
