Another disparity I just noticed. B1021 allows max of 5. Yet there are 6 total events including the main, Pilot 1,2,3 and Post 1,2
Custom Tuning Services
One of the elements that I am really impressed with, is the ability of the induction system to lower ambient from 14.2 to under 9 psi, see boost. The MAF is highly reduced as low load/idle conditions approach.
This is why it would be valuable to see the intake valve, but I don't see a PID for it. I know next to nothing about this, and am assuming that this pressure is only possible with a metering restriction located pre-compressor?
In BBL
IAFVCMD
intake valve motor commanded %
I guess you have just managed to convert me.
unless in regen?
2007.5 RCLB 4x4 WT LMM 8594OS
It's interesting to compare B1021 in the LMM's to LBZ's.
LBZ's had no limitations on injection events vs voltage from the factory.
LMM's have that table refined from the factory.
Since most electrical systems run in the 14.4-13.8 vdc range while running it looks like they limit injections to (4) after 2800 rpm and (3) after 3600 rpm.
Do we know that the voltage referenced is system bus voltage?
