Results 1 to 4 of 4
Thread: need help with lanos 2001
    Jan 2010
    Default need help with lanos 2001
    hey,
    i'm new at this so after some reading i connect my leptop to the car's aldl.
    when i 'm trying to to start reading data, with any xml, it gives me this error:
    13:47.863: Opening COM1 8228,8,N,1
    13:48.818: Start macro: Clear diagnostic trouble codes: CLRDTC
    13:48.828: Send: $F5,$57,$0A,$00,$AA
    13:48.950: Com timeout: Expecting frame header byte
    13:48.958: Stop macro: Clear diagnostic trouble codes: CLRDTC
    check run:
    21:01.961: Check vehicle interface...
    21:01.966: Waiting for Aldl bus silence of at least 50ms...
    21:02.016: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    21:02.027: Max232 interface detected OK
    21:02.030: Scanning for heartbeat and chatter frames...
    21:02.030: Waiting for Aldl bus silence of at least 50ms...
    21:02.187: Com timeout: Expecting frame header byte
    21:02.198: No chatter found
    can anyone walk me step by step?
    It looks like your interface cable does not echo the Max232 commands back to the PC. In that case go into the properties and uncheck the "Max232 Echo" check box.
    Jan 2010
    FWIW some Daewoo's have trouble comunicating with scan tools. We have the actual Scan-100 DAEWOO scan tool at the shop I work for. Some cars will not conect to that and we have to try and hook up a small hand held scan tool to see if we can read codes and live data. You might also try another scan tool and see if it will conect to that. Also check the fuses... I cant remeber wich fuse it is but sometimes That will also cause an issue. So far I have seen 2 Daewoo's that would not conect with any scan tool. It could also be a loose pin at the ECU. Unfortunitly most customers won't spend any money to Diagnose the problem.
    Good luck!
    Jan 2010
    thanks i gonna try again this weekend.
    which .xlm should i use for my lanos 1.5 2001?
  1. 2001 5.7 v8 mpi ohv
    By Spuco in forum Vortec V6/V8 Specific
    Last Post: February 28th, 2010, 05:11 PM
  2. Tuning a 2001 z need help
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: August 7th, 2009, 03:31 AM
  3. 99 os-2001 os?
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 01:39 PM
  4. Australian Daewoo Lanos 1999 Strange Data
    By leibhold in forum EFILive V4
    Last Post: November 25th, 2008, 12:40 AM
  5. 2000 OS vs 2001 OS, different?
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 26th, 2008, 06:15 AM
