Thread: BBL Error 0281
    Jan 2010
    Default BBL Error 0281
    Cant get past this error?
    I believe i have done everything listed in this forum to set it up but still no luck.
    E38 PCM on a VE HSV commodore 2007
    What firmware are you using? Update to the latest beta software (7.5.6 build 104 and 8.1.2 build 84 plus firmware 2.06.24) and report back!
    Im not on my computer (school computer) so I dont have EFILive installed, whats that error message? Have you setup the PIDs you want to log and programmed them to your V2 using EFILive Scan & Tune?
    Quote Originally Posted by LS2_307 View Post
    Is the ignition turned to the "run" position?
    Does FlashScan power up when connected just to the vehicle?
    When does that error occur - i.e. what are you attempting to do when you get 0281?
    Do you see a "CAN 02" message in the lwer right corner of the FlashScan display?
    Jan 2010
    Have updated to this software.
    error is "no data received"
    Have setup the pids in V2
    Is the ignition turned to the "run" position? Yes
    Does FlashScan power up when connected just to the vehicle? Yes
    When does that error occur - i.e. what are you attempting to do when you get 0281? when I go to data logging and select record data
    I see CAN 01
    It records ok using the laptop
    Still trying and thanks for the prompt replies
    (beginner) 50yrs young....
    After you get the error, select the option:
    F2: Scan Tool -> F3: Scan Options -> F1: Save Trace File.
    Then using EFILive Explorer, copy the saved trace file to your PC and email (as an attachment) it to me at paul@efilive.com
    Jan 2010
    Done
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. Want to start using BBL - $0281
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: May 28th, 2010, 03:49 AM
  3. $0281 error when clearing DTCs - fixed
    Last Post: May 27th, 2008, 11:14 AM
  4. Error $0281 on DTC Clear?
    By Donovan in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 02:59 AM
