Results 1 to 6 of 6
Thread: lc-1 serial to efi-live issues
    Jan 2007
    Default lc-1 serial to efi-live issues
    Having a slight issue when I try to log serial lc1. WB works fine with the innovate DB gauge when I try to serial log thru efi I run into issues. I believe the WB is communacating with EFI since it did do a free air test but it didnt show it on my V2 only on my gauge.
    I am running FW 2.06.12 and bootblock 2.06.02.
    I have the TAQUICKNESS serial cable. I noticed in his instuctions in his screen shot there was a com port in and out all I have is a comport.
    I also believe that after I updated everything, my scantool doesnt seem to be reading correctly. I am sure it is something I am doing wrong I just need some to point me in the right direction.
    Nov 2006
    Try theses settings:
    COM Port: Wide-O2
    WO2 Type: Innovate
    A/D PIDs: YES
    Ser PIDs: YES
    WO2 Data: AFR & λ
    Remember to press OK after changing the settings so they are programmed.
    LC-1 WBO2
    Update your firmware, latest is 2.06.24. Download the latest public beta software to get the firmware.
    I know its stupid, but do you have the null adapter plugged into the IN serial cable that goes to the LC1 controller? Nowhere did any instructions I read said to do this (they did for reprogramming the controller but not for serial out) so I was scratching my head for a few minutes before I tried it.
    Jan 2007
    I will def try that Mr., hopefully it works.
    Erik I did not have the null plug in the in the in serial plug...
    I am not even sure where mine is , DAMN.
    As for the update I just updated everything yesterday with whatever the public release had in it. I might have to look at the beta releases.
    But first thing first where is my null plug.....lol
    I guess off to radio shack i go.
    Nov 2006
    You are going to need the terminator plug.
    You can't connect to the LC-1 with a laptop or Flashscan without it plugged in.
    IIRC it won't work at all without it plugged into the LC-1 or the last device
    in the "daisy chain" formation.
    LC-1 WBO2
    Jan 2007
    Thanks!!! I will get back to you guys once I get the termi plug.
    Cant find it anywhere
  1. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  2. LM1 through the 9 pin serial...
    By rubbersidedown in forum FlashScan V2
    Last Post: August 2nd, 2008, 03:00 AM
  3. OBD to serial to USB
    By kjhansen in forum EFILive V4
    Last Post: April 6th, 2008, 02:20 AM
  4. can we use the serial on the lc-1 in efi live?
    By warscout2 in forum General
    Last Post: February 28th, 2007, 04:40 PM
  5. Live tuning for RFI-Live??
    By Bob's Garage in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2005, 06:27 AM
