Results 1 to 2 of 2
Thread: Fueling Tables
    Oct 2006
    Default Fueling Tables
    I asked this question of someone else and wanted to see what the answer might be : 'Can you tell me why then , the MAP in LC (lean cruise) X and Y axis are GM.DYNCYLAIR_DMA and RPM , but the Fueling Table we have is kPa and ECT ? I don't see the correlation , doesn't the X and Y axis need to be the same seeing the earlier is modified by the latter , how does the PCM use it , and is there maybe a table missing from EFILive that would correlate the two ?
    If you did a "copy and paste with labels" between the two tables it will not work seeing the labels are completely different . Doesn't there need to be some familiarity (same X and Y Labels) between the two ?
    Just curious !'
    2006 Trailblazer
    Oct 2006
    No they dont need to correlate with each other in terms of axis as they will be monitoring different conditions to operate. It is the same as the high/low octane spark table using airmass & RPM compared to your commanded fuel tables different axis.
    To tune this table all you need to do is log the axis with wideband AFR as the data. Filter out any data that is not in the cruise zone where you want to lean the mixture. Calculate in EQ how much enleanment you want in those cells. Subtract this value from 1.0 & paste the resultant value to the cell.
    The Tremor at AIR
  1. N2O fueling.. ONLY VE?
    By Highlander in forum Custom Operating Systems
    Last Post: December 20th, 2009, 06:27 AM
  2. Boost fueling tables
    By limited cv8r in forum Custom Operating Systems
    Last Post: March 17th, 2009, 04:17 PM
  3. Still trying to get fueling there
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2007, 12:42 PM
  4. o2 sensors and fueling
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2007, 02:16 AM
  5. Over Fueling 408
    By overdrive915 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2007, 07:18 AM
