Results 11 to 20 of 21
Thread: 4L60E, Yank 3600 Stall, 3.42 gears TCC Apply/Release
  1. #11
    Lifetime Member jfpilla's Avatar
    After watching the video, it seems like you have a lock unlock problem and not chatter. If that's so, try replacing the "3" 256 values with appropriate values. The 12.5 % TP 256 may be a problem.
    You know you can copy and paste from EFI to the worksheet.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  2. #12
    Nov 2008
    Quote Originally Posted by jfpilla View Post
    OK so I am looking into that, but what about changing the 4<3 downshift? I have 3rd not locked till 25% TPS, what do you think about that? I am really wanting 4th locked for at least some milage, but when I give it some TPS for light acceleration such as going up a hill or holding speed on a hill. Just throwing it out there for some discussion. I am about over the trans program!
  3. #13
    May 2008
    Have you tried mine yet?
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
  4. #14
    Nov 2008
    Quote Originally Posted by LS1_Dragster View Post
    Not yet, I was going to try later today.
  5. #15
    Quote Originally Posted by 1fastgto View Post
    What I suggest is:
    -Eliminate 3rd gear lockup. With a loose converter it will give you fits trying to work on your problem. In my opinion and the experience of many, 3rd lockup with a loose converter does not work well. When the 3rd to 4th shift occurs it drops out of lockup and the RPMs jump up. It feels like you've gone to a lower gear. You can go back to it, but for now work on one thing at a time.
    -Copy and paste the values from the worksheet to your tune. We know they work with the same gears and converter as yours.
    -If it all works out you can customize the trans to to your liking.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  6. #16
    May 2008
    I also have my firebird with a 3500 stall and a 4L80E that works like a dream. I even have lockup in 2nd, 3rd and of course 4th. With it so loose I lock it in 2nd just so it doesn't sound like I'm trying to race the guy next me at every light. If you want to look at it I will upload it.
    Lee
  7. #17
    Nov 2008
    Lee
    Thanks Lee would love to see it too. I think the problem is my converter is pretty damn tight, I didnt get too much time to mess with it yesterdad and it supposed to rain here today and tomorrow so I will try to mess with it some more this weekend at some point.
  8. #18
    May 2008
    I'm pretty sure this is the tune where I lock it in 2nd, I've upgraded to windows 7 and I havent installed EFILive yet so I cant check.
    What I found that stopped my Vigilante from shuttering was TCC pressures, now when it locks it feels like a shift. Plus getting the up/down shifts to sync with the converter lock/unlock was the trick for making it enjoyable to drive.
    Lee
  9. #19
    May 2008
    I was just looking at your tune and the TCC Solenoid values in my opinion is whats causing or at least attributing to your shudder. If nothing else copy my values for D2905, D2904 and D2903 and see what that does.
    Lee
  10. #20
    Apr 2007
    I also recommend eliminating 3rd gear lock up for now to see if that eliminates the problem. I would lower the 4th gear lockup mph values. Your 4th Gear lockup mph values are crazy high between 18.75%-37.50%. I run a Circle D 5C and it locks much lower than that without problems.
  1. Need TCC Apply & Release speed settings
    By yb normal in forum Allison 5 & 6 Speed
    Last Post: May 18th, 2010, 11:10 AM
  2. TCC Apply Rate
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 13th, 2010, 05:29 PM
  3. T42 TCC Apply Rate?
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 26th, 2008, 01:30 AM
  4. 2600 to 3600 stall TQ
    By driver456 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 13th, 2006, 11:43 AM
  5. Tuning for a big stall. yank 4400
    By smokin2002 in forum Tutorials
    Last Post: June 8th, 2006, 12:49 PM
