Results 1 to 6 of 6
Thread: TCC Apply Rate
    Jan 2010
    Default TCC Apply Rate
    So the 4L80e and the 4L60e since about 95 have had this PWM valve that lets the TCC be partially locked.
    I don't really like it. I don't like the way slipping clutch feels, I think most of you guys probably share that opinion.
    Now the 4l60e can be fitted with a retrofit valve from the pre-1996 trucks to make lockup a either locked or unlocked, not locked, unlocked, and kind-of-locked.
    In this way lockup feels like shift unto itself.
    There is no valve like that for the 80e, there's a spring that can be replaced with a softer spring in the PWM valve that makes it firmer but that's about it as far as I'm aware.
    I'm planning on getting a custom tune for my truck, an 01 with the 4L80e, I think I might want to have that, or at least have my PCM tuned so that it acts more like that.
    Anyone ever tried this? Is it feasible? Is there any advantage or disadvantage to it?
    Dec 2008
    Yep just set it to D2903 and D2904 to 100.
    Jan 2010
    And it will give lockup a quick firm feel?
    Dec 2008
    Quote Originally Posted by 2500ak View Post
    Yep feels like another shift. Just be careful and don't lock it up too early though, or it will be too harsh. It just takes a little experimenting.
    Jan 2010
    Excellent, that's just what I needed to know.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    I had the same question about and I am glad to see that someone else had the same problems. I am going to try out on Monday and see how it works!
    I am using a 0411 PCM as a trans controller on a 4L80E transmission behind a Detroit 2 stroke diesel in a Ford pickup truck (long story). Works fairly well, just had slippy lockup !!!!
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
  1. Convertor apply percentage
    By rcr1978 in forum Allison 5 & 6 Speed
    Last Post: May 20th, 2009, 08:46 AM
  2. AutoCal Beta Test - Apply Here
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: February 27th, 2009, 11:18 AM
  3. T42 TCC Apply Rate?
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 26th, 2008, 01:30 AM
  4. TCC apply shudder solved
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: March 27th, 2006, 02:02 AM
  5. TCC Apply/Relase Rates
    By joecar in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 22nd, 2005, 12:48 PM
