Results 1 to 4 of 4
Thread: How many MM3's can you command?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default How many MM3's can you command?
    I have a question, I believe someone told me that on the newer LBZ/LMM trucks you could command whatever fuel amount you wanted, but the truck would only deliver 125mm3 at the most. (mine delivers 126mm3)
    Is it the same for the LB7/LLY trucks, do they max out at 125mm3? I don't need more than that, and if I do I'll get it through pulse width and fuel pressure, I'm just curious is all. Thanks!
    Peace Through Torque
    www.PunisherPerformance.com
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Quote Originally Posted by LBZoom View Post
    I was told the same thing
    07 El Bee Zee
    Little faster than stock...
    Nov 2008
    thats interesting. So how exactly does the ecm determine mm3 when we start messing with pulse width and pressure? I have always wondered this? or does it really know the exact mm3?
    Apr 2006
    Once the pulse width table is modified, the MM^3 value becomes a reference only.
  1. AFR Command Air Fuel Ratio
    By james01ss in forum Gen III V8 Specific
    Last Post: October 6th, 2008, 01:33 PM
  2. What AFR do you want to command at Idle?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:06 PM
  3. A0008 OL ECT Command Fuel Multiplier
    By dc_justin in forum Custom Operating Systems
    Last Post: December 11th, 2006, 07:08 PM
  4. CALLING EFILIVE....Can I command Pulse width somehow??
    Last Post: June 9th, 2006, 03:45 AM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
