Results 1 to 4 of 4
Thread: Help Truck Wont Start - Flash messed up somehow?
    May 2005
    Default Help Truck Wont Start - Flash messed up somehow?
    I changed a shift point the other night and then hit the flash cal button just like normal and it erased memory, started to write and then froze about 4 seconds in. After I waited for several minutes to be sure it had indeed froze, I went ahead and hit the stop button. Now the truck will not start and when I try to read or flash and gives the message:
    pcm did not accept the bootloader, reason: efilive could not unlock pcm. Then it wants me to enter the unlock code.
    What does this mean? Did I cook the pcm? Any way to fix it? I have never locked the pcm.
    Best regards,
    Ben
    1999 RCSB: P1SC, 57lb inj, E-fans/34\" rad, 3:73-Eaton 18\" Toyo\'s, Flashscan-FJO, Griffin IC, FLP level 5 and PI 10.5\" 3-disk....
    Ben,
    If this was a cal only flash then you should always be able to recover.
    'Worst case', this should not be needed, but pull the fuse for the PCM power for a minute or so then retry.
    If the PCM is missing the calibrations then when you try to flash the program it should just give a message that the PCM is missing the calibrations and will be recovered.
    If this does not work look in the folder -
    \My Documents\EFILive\V7\Bug reports
    for the last 'download' blx file that was created and Email it through to us.
    either ross@efilive.com or support@efilive.com
    May 2005
    Okay, that fixed it. Forgot about those fuses. Thanks Ross.
    Ben
    Ben,
    The fuses should not need to be pulled to retry a failed flash, they should never be pulled on a full flash fail.
    But sometimes these things happen and I can't explain them :roll: :oops:
  1. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 01:39 PM
  2. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 07:33 AM
  3. sterio swap and truck wont start
    By pullincrazy88 in forum General (Diesel)
    Last Post: September 2nd, 2009, 01:42 AM
  4. help truck wont crank?
    By dpduramax in forum Duramax LB7
    Last Post: May 12th, 2009, 05:06 AM
  5. Truck wont shift and getting a U0100
    By heathgu in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 20th, 2007, 12:39 PM
