Results 1 to 5 of 5
Thread: Any way to dampen the PLX wideband output?
    Jan 2010
    Default Any way to dampen the PLX wideband output?
    Any way to reduce the sensitivity? The after decimal units change very quickly (00.XX).
    Lifetime Member macca_779's Avatar
    Jan 2007
    Thats not really a bad thing mate. I cant think of a simple way to dampen the data input but remember if your building the WB data into a MAP each populated cell is a sum of all the data collected there and averaged when you use the X option. So in a way that should get you what your after anyway.
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    I've had a PLX M-300 for about five years and I agree that the AFR readout to two decimal points of accuracy is annoying. In time, you may learn to simply ignore the bouncing digits. If not, consider taping over the last digit as a mask.
    On another front, my day job is an aircraft electronics engineer and I can tell you that damping the display via circuitry is more than even I would want to take on considering the cost to benefit ratio. You don't want to damp the analog signal any more than using the tiny capacitor that PLX provides or your logged data will be sluggish and inaccurate. PLX and others would have done better to make the user's display something like a linear, color-coded bar graph like they have done on their round accessory gages.
    Hope that this helps.
    Steve
    Nov 2006
    Is this just for the display on the data tab, map, gauge/chart?
    Are you using V1 or V2?
    LC-1 WBO2
    Feb 2004
    I think that he's talking about the display itself and it has nothing to do with V1 or V2.
    Steve
  1. How to match wideband output to {B3601}
    By mr.prick in forum Tutorials
    Last Post: September 20th, 2010, 06:46 AM
  2. DSP Output changes
    By GMPX in forum Duramax LB7
    Last Post: November 12th, 2009, 01:43 PM
  3. lc1 wideband output ?
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 1st, 2009, 02:19 AM
  4. E38 VSS output
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: June 29th, 2009, 07:14 PM
