Results 1 to 1 of 1
Thread: injection timing after pilot c,d?
    Member SGFastMax's Avatar
    Apr 2009
    Default injection timing after pilot c,d?
    im tuning an 03 lb7 and im copying my hot tune into my new dsp5 tune. the regular tune has injection timing C and D seperate. the dsp5 program has them together or in one table. which one do i use? both tables are opposite, table C activates the main injection later in the low RPM range as apposed to table D and D activates the main inj. later in the upper range as apposed to table C.
    Or is this telling me that i should use table D?
    When not running the DSP program the ECM will use
    {B0929} "Injection Timing After Pilot Base (D)"
    or
    {B0928} "Injection Timing After Pilot Base (C)" for early LB7.
    im thinking i would want to use the table with less degrees in between the pilot and main in the low end and the most in between fading towards high end.
  1. Injection Timing / Pilot
    By Lennart in forum General (Diesel)
    Last Post: January 20th, 2012, 02:05 AM
  2. Pilot Injection Adjustments for LBZ
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 12:52 AM
  3. Adding up pilot injection timing values
    By turbo_bu in forum General (Diesel)
    Last Post: January 28th, 2008, 03:19 AM
