Results 1 to 9 of 9
Thread: How To Tune For Larger Injectors
    Apr 2005
    Default How To Tune For Larger Injectors
    I just bought EFILive about a month ago and I am going through the learning process but I would like a little help on this one.
    I just bought 60lb/hr injectors and I was wandering what I will have to fool with to tune the PCM for them.
    Any help is appreciated.
    Jul 2005
    The injector flow rate table has to be set up properly.Am at home so cant give you the table number.
    Look on LS1tech under pcm there is a spread sheet there that you can use.
    \"You Can Never Have Enough Horsepower\"
    Apr 2005
    I know the table you are talking about.... It has injector flow rate and I believe stock it starts out at like 26lbs/hr and ends at like 32/hr. Do I just have to change this all over to 60lb/hr???
    Thank you for your reply.
    Apr 2005
    Sorry to bother again but I am also having trouble finding that spreadsheet on LS1Tech, Could you send me a link of the page where its located???
    Jul 2005
    here it is
    Apr 2005
    Thanks a ton!!!! I will let you know how it went hopefully in a day or so... Again thanks!!!!
    Apr 2005
    Ok... I have the zip file but I am unshure what to do with it. What do I unzip it to and what do I open it up with??
    Thanks again
    Jul 2005
    Unzip it anywhere. Mine is in my efilive directory.
    It's a Micosoft excel worksheet.
    Open it enter your injector specs and pressure tested at.
    Then enter your current fuel pressure and copy and paste the column into your injector scaling table.
    Apr 2005
    Thanks for the reply again.... It was a dumb question... I opened it with my notebook wich doesnt have my Microsoft Office on it so I didnt recognize the file type, I reopened it with my desktop and it opened right up in Excell. I believe it will work great!!! I already pasted the new flow rates in but I have yet to install the tune and the injectors. I will let you know how it goes.
    Thanks again!!
  1. 7.4 Larger injectors, which ones..
    By Stamm1 in forum Vortec V6/V8 Specific
    Last Post: January 14th, 2017, 02:55 AM
  2. best injectors to tune
    By pdasterly in forum Gen IV V8 Specific
    Last Post: December 9th, 2009, 03:24 PM
  3. larger high impedance injectors
    By 496chevy in forum Custom Operating Systems
    Last Post: February 7th, 2009, 07:02 PM
  4. larger tune maps
    By limited cv8r in forum Tips and tricks
    Last Post: July 17th, 2008, 03:15 PM
  5. Update on my tune since swapping to larger injectors..
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: April 28th, 2008, 01:32 AM
