Results 1 to 10 of 18
Thread: Knock at WOT
    Jan 2010
    Default Knock at WOT
    I'm just starting to log data and I noticed I'm getting some KR at WOT. Also injector duty cycle shows 86% that seems high for a car with only intake manifold, throttle body, and cat-back exhaust mods.
    My PCM is on a stock tune so what could be causing this KR? I attached the log file, let me know what you guys think. Thanks.
    Updated: Added two extra logs one with less knock.
    Oct 2006
    Not unusual to get knock in a stock tune at WOT , stock tunes are so generic and just close enough for all .
    2006 Trailblazer
    Some I6 TrailBlazers have up to 5-6 degrees of knock!!! I have logs to prove it (somewhere...)
    Nov 2006
    There's something not right about that log, was it filtered before it was saved?
    LTFTs are high and positive during PE (7%) and
    AD1&2 are stuck @ 3.4v-3.8v so no way to add WBO2 data if you had one hooked up.
    Are stock tunes that bad?
    LC-1 WBO2
    Jan 2010
    Quote Originally Posted by mr.prick View Post
    Completely stock tune and that log was not altered in anyway. Stock tunes are pretty bad commanded AF is 11.7!
    Quote Originally Posted by Chevy366 View Post
    Thats good to know, looks like I'm going to have to do a lot more reading and work on a tune for my car. Thanks guys!
    11.7 might be cat overtemp protection kicking in.
    Nov 2006
    That is stock PE ratio for a '98.
    The positive LTFTs during PE points to more fuel being needed or
    maybe Ethanol in the tank.
    I filled up the other day and saw my LTFTs go positive,
    making me believe I got more than I bargained for at the pump.
    I have heard that 97-98 have inferior KR sensors too.
    LC-1 WBO2
    Oh, I see... I'll have to look more closely at a 98 file...
    The 98's suffer from KS problems, constistant 4° KR... there is an upgraded KS and sub-harness from GM.
    Altho his KR looks like it is sawtooth shaped indicating it might be real...
    I have read about overly-rich spark knock, but I don't think this is the case.
    Jan 2010
    I am in the north east where we all have 10% ethanol at every pump, it sucks.
    How much will having 10% ethanol in the gas change the tuning process? What things should I look out for because of this?
    Added two more log files at the first post.
    I was thinking doesn't torque reduction in the stock tune pull timing on shifts? Is that done by using KR or could it cause KR to happen?
    TR just reduces timing to prevent knock... it doesn't cause KR to happen, and it doesn't use KR to reduce timing...
    The value you see for the KR pid is in response to knock/noise being detected by the knock sensors... the PCM determines how intense it is and sets KR which is subtracted from the final spark advance (i.e. SPARKADV reduces by KR amount).
  1. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  2. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
  3. 1:50,75 AFR-- no knock ??
    By germanvette in forum Gen IV V8 Specific
    Last Post: May 6th, 2007, 04:40 PM
  4. Knock knock.... who's there? KR
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 24th, 2006, 10:59 PM
  5. Can't get rid of knock
    By jsttry in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2005, 12:56 AM
