Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: B3601 value for E10
    Oct 2007
    Default B3601 value for E10
    i have it set for 14.12 afr.... so it changes my B3647 accordingly...
    *NOTE* I RUN IN OLSD....NO MAF
    question is....
    should i leave my crusing and part throttle @ 14.39 afr and my wot @ 12.07 ( changed to this automaticly when i entered 14.12 (stoich for E10) afr in B3601 )
    OR
    leave my crusing and part throttle afr @ 14.91 and my wot afr @ 12.50 while still maintaining 14.12 afr in B3601 ( B3601 set to 14.63 afr )
    remember E10 is roughly 1/2 point fatter in AFR....
    ALSO, E10 is at every gas station now as far as i know
    THOUGHTS????
    THANKS
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Oct 2006
    The percentage increase for PE or WOT should be a constant, so I would leave it as is.
    The Tremor at AIR
    Oct 2007
    leave WOT @ 12.07 AFR....????
    Jan 2010
    Quote Originally Posted by WHYTRYZ06 View Post
    12.07 x 1.035 = 12.49AFR
    12.07AFR on E10 is equivalent to about 12.49AFR on E0 (regular fuel).
    Source: http://forum.efilive.com/showpost.ph...&postcount=169
    Oct 2007
    Quote Originally Posted by Epox4life View Post
    rite so leave it at 12.07 afr... for E10
    Aug 2015
    I know this is an old thread, but I encourage anyone who's tuning for E10 to actually test the fuel they use. A chemist at a racing gasoline blender told me a couple of years ago that most of the ethanol blended gasoline on the retail market is actually somewhere between 7 and 8% ethanol rather than 10%. I've also tested several samples of ethanol blended gasoline from premium gas pumps in my area and sure enough, they all were about 7-8%.
    As a result I assume it's all E7 and set my stoic value at 14.2:1 = lambda 1.0.
    Hib Halverson
    just another f'ing "Tuner In Training"
    Quote Originally Posted by Hib Halverson View Post
    +1
    I agree...
    and the test kits are cheap.
    Aug 2015
    "Test kit"? I didn't realize there was such a thing.
    I guess I made my own test kit. I bought a graduated cylinder from Amazon. I put 100 ml of pump gas in it then add 10ml of water. Shake it up then let it sit. After a while the ethanol and water "settle out" at the bottom. Say you have 100 ml of gasoline "floating" on 18-ml of ethanol and water that's about "E8".
    Hib Halverson
    Yep, that's what the test kits are for about $5, some include a water soluble dye to better see.
    Apr 2007
    I'm about to start Tuning my 03 sierra and am wondering... do I need to change my B3601 to 14.12 - 14.2(depending on alcohol content) before I start tuning? I'm assuming yes.
    If yes, do I then need to change the information in the software for my dual LC-1 Widebands pertaining to lambda?
    2003 GMC Sierra Denali
    6.0L, LQ4, AWD, 4WS
    Volant CAI w/ Scoop
    '06 Silverado E-Fans
    High Flow Cats
    Volant Cat-back
    Morimoto HID full retrofit /w all on mod
    All exterior lights LED (VLEDS) (except headlamps)
    LT285/70R17 Open Country AT II's
    Future: skyjacker 3" lift w/ rear add a leaf(hopefully)
  1. B3601 and returning to CL
    By Gregs in forum Gen III V8 Specific
    Last Post: May 1st, 2010, 12:48 AM
  2. Commanded AFR ≠ {B3601}
    By mr.prick in forum Gen III V8 Specific
    Last Post: March 21st, 2010, 11:33 AM
  3. B3601 equivalent in E38
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 8th, 2009, 12:02 AM
  4. Logworks and {B3601}
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2009, 06:24 PM
  5. B3601
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2005, 11:24 AM
