Sorry if this was asked before.
If the air mass per cylinder can be determined from the VE table using the following formula:
g/cyl = VE*MAP/charge temperature
Ve is in g*K/kPa,
MAP is in kPa,
charge temperature is in degrees Kelvin.
How is total engine air flow calculated and should that be the same as what your MAF is reading?
