Results 1 to 10 of 12
Thread: Load Percentage PID/Calculated Value
    Default Load Percentage PID/Calculated Value
    OK so does anyone know how to make the Load Pct PID actually work on a P10? Every P10 Ive tuned starts at like 30% load at IDLE and goes to 100% by the time you're at 25% throttle position.
    How does the load PID use MAP, as in what is the equation behind the scenes so I can try and figure out a solution?
    Having a commanded AFR would be nice too, last I checked SAE.LAMBDA, GM.EQUIVRATIO and GM.AFR didnt work...
    Bumpity bump, Id be happy just knowing what parameters are used to calculate the Load % axis in the VE tables so I can make a calc pid...
    May 2010
    Have you figured anything out with this?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Shawn posted (or at least I thought he did) about the formula for the standard LS1 Load % PID. Unfortunately that uses GM.MAF, which we obviously dont have because we're SD/alpha-n.
    Ive heard that TunerCats has the VE tables in a normal format, not sure but I believe g*K/kPa so I know thats part of the equation.
    Jul 2008
    Yes, I had it posted for awhile, but figured it was not applicable....
    Lifetime Member schwoch1's Avatar
    Jan 2009
    I have TunerCats, I would be happy to take a look at a cal if you happen to have one in .bin or .cal format. Let me know...
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
    Ah dang Mike, I dont have a P10 file in anything but .tun/.ctd. Probably could get one in HPT format too.
    Anyone got a .bin of a P10?
    Jan 2009
    I will check on the Monodax website, I think I seen one there a while back. Can't look at the cal tonight anywho as all my Windows PC's are down at home and all I have up and running is a Mac (go figure) and our tuning softwares and Mac do not play well together!!! I will see what I can do for ya!!!
    Edit: Got one.....says it is for a '04 Envoy 2wd with a LL8. I will take a peek tomorrow. What table are you looking for again???
    Mike
    The VE tables, what are the units? RPM vs. ??? In EFILive its RPM vs. Load %.
    Jan 2009
    I attached two screenshots of what fuel tables are avaliable, pick out which ones you want to see and I will get you the appropiate screenshots!!!
    Hope this helps
    Mike
Name:	LL8 fuel table 2.JPG
ID:	10461Click image for larger version.
Name:	LL8 fuel table 1.JPG
  1. Fuel_Economy calculated pid?
    By Zeus in forum General
    Last Post: June 3rd, 2013, 04:23 AM
  2. Formula help for Calculated Pid
    By vetteboy2k in forum Black Box Logging
    Last Post: December 21st, 2012, 10:16 PM
  3. Calculated PID's
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2007, 09:55 AM
  4. Calculated PID Problem
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 09:44 AM
  5. Can't get calculated PID to work for MPG
    By PSWired in forum General
    Last Post: August 7th, 2005, 07:29 AM
