I am working on the black magic injector tables in my tune. I started out with stock 26.6lb/hr truck injectors (05 Chevy 6.0L.) After Heads/Cam/Headers I figured it would be wise to get some bigger injectors.
I bought the new shorty LS2 injectors which are flowmatched at 42lb/hr @ 4 bar (58psi). At first I copied as many tables I could from a LS2 tune to my tune. I dont like to assume that both PCMs run the same way especially when there is two different LS2 tunes (at least injector data.)
Long story short, I called John from FIC (Fuel Injector Connection) and got all the raw data I could from the injectors I bought from him. He faxed over what he had, and I found out that most of it was written in Greek.
Attached to this post is what he sent me via fax. I want to get the proper data from that data and somehow put it in my tune. I am running a GenIII PCM. If I looked at it long enough Im sure I could figure it out, but I'll ask here first .
Let me know your thoughts,
Sam
