I am interested in the EFILive Tuning Tool. I was going to purchase the cable, to go with it. What else do I need to buy. All I would be using this for is speedometer calibration since I have no other tuning experience. All help is appreciated.
Hello,
This system is actually a little overkill for tuning speedo. Pricey too, $750-800 for the latest v2. It comes with 2 licenses and any PCM you modify costs 1(you never get it back), they are $99 each.
I would suggest a frequency modifying box of some kind. I know Dakota Digital sells them, there are many others. Those are made just for speedo re-cal.
Good Luck,
S
Here are some helpful links:
Basic Tuning Links, Joecar's "lost bolts", Joecar's BBL setup pics, GM PCM Info, Acronyms for beginners, -- SSpdDmon's Tuning Method, Tuning Spreadsheet, Idle Tuning
Personal Junk, Saved Information,
So I can't just buy the ODB2 cable, and use the EFILIVE program I downloaded off of this website?
No, the two modules EFILive sells(v1,v2) are very specific to this system. I have other OBDII systems and they don't work with EFILive. There are a few other systems that will cross, but NONE of those will work with EFILive.
S
Understood. I hate to ask this here. Anyone know a free program we could use?
what are you trying to tune mabey i might be able to help
James AKA FREIGHTTRAIN
2008 gmc 2500
38' toyos 22' rockstars 7' bds lift
efi live, propane, water meth, intake, stright pipe, studs the rest is top secret
Were are you located at?
2008 gmc 2500
