In my personal experience, contrasting conventional wisdom, I found lower pressure for lower load to be the way to go, with do real downside in efficiency.
It realistically comes down to keeping pulsewidth to a reasonable CADeg. At higher loads, you would really need the pressure to lower CADeg, which can get as high as 30-40 degrees is some of the wilder power requirements.
