Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Fuel Rail Pressure's relationship to fuel economy.
  1. #21
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Okay I got it now. Thanks for the help guys!
    Peace Through Torque
    www.PunisherPerformance.com
  2. #22
    The CP3 is a parasitic accessory.
    Custom Tuning Services
  3. #23
    Senior Member DmaxHawk's Avatar
    Apr 2008
    What would be better?
    07 El Bee Zee
    Little faster than stock...
  4. #24
    Nothing. Just pointing out that higher fuel pressure equals more parasite. When commanding more pressure without a commensurate power increase requirement, the impact (IMO) is more drag.
    As Bballer said, there may be some burn effect differences that are not as easy to predict.
  5. #25
    Mar 2007
    I figured the CP3 is always making 30k internally, but the fuel pressure regulates output of that pressure to the rail. What side of the pumps is the FRP on low side or high side. My guess is low side, but I always thought it was on high side.
    2007.5 RCLB 4x4 WT LMM 8594OS
  6. #26
    regardless of output, it doesn't work for free.
  7. #27
    Jan 2008
    Good point, i forgot to mention that.
  8. #28
    Apr 2008
    Quote Originally Posted by LBZoom View Post
    How much did you lower it by?
    07 El Bee Zee
  9. #29
    Mar 2007
    I just figured its hp scavenged was a given amount at a given RPM range not a variable hp amount at a variable pressure level. Can anyone confirm this on bench tester based on resistance?
  1. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  2. How to restore actual fuel rail pressure button?
    Last Post: November 24th, 2009, 04:59 PM
  3. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  4. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
