Results 11 to 20 of 29
Thread: Fuel Rail Pressure's relationship to fuel economy.
  1. #11
    Jan 2006
    In my personal experience, contrasting conventional wisdom, I found lower pressure for lower load to be the way to go, with do real downside in efficiency.
    It realistically comes down to keeping pulsewidth to a reasonable CADeg. At higher loads, you would really need the pressure to lower CADeg, which can get as high as 30-40 degrees is some of the wilder power requirements.
    Custom Tuning Services
  2. #12
    Lifetime Member LBZoom's Avatar
    Jun 2008
    I'm going to experiment with my fuel pressure some more in the next couple weeks, started a new job with about 30 miles of interstate driving every day so I should get some good testing in. I'm going to attempt to lower my pressure slightly, and I'll have to open my pulse some to still allow the fuel in I suppose... correct?
    Or should I maybe lower my crusing pulse time and map the actual FRP vs. my current base FRP table and go that route? I guess only experimentation will tell.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
  3. #13
    Jan 2006
    This is by no means the definitive technique, but I will say what worked for me on a long road, where I made plenty of learning mistakes before I settled on this. Find a pressure table that you like the feel of (easier said than done). Then create a pulse table that keeps around 800-900us as you climb the power ladder. As you approach your pressure cap, pulse should begin to grow past 1000us into the real power range. This was very important to my end product refinement, and this one process can take weeks or months if you are a perfectionist.
    No load highway cruise uses 25-35HP. For me, I find no use for more than 60Mpa. That should give a good place to start from. Eventually you will draw your own conclusions, but trial and error is definately involved. Develop the buttmeter to tell you what you need, trust the force. Eventually, you will develop keen ideas of what changes the feel of things, and make correlations that the Dash will provide. I use dashB almost exclusively.
  4. #14
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Quote Originally Posted by killerbee View Post
    So lower pressure will lower CADegs? I'm a little confused
    07 El Bee Zee
    Little faster than stock...
  5. #15
    Jan 2006
    No. As you probably know, lowering pressure, changing nothing else will increase CADeg.
    I know some are wondering what CADeg is. It is the pulswidth measured as degrees of crank rotation.
  6. #16
    Apr 2008
    Ok so lowering pressure will increase the pulse because it is still trying to get the same mm3s into the cylinder? The increase in pulse is compensation for lower pressure?
    Is this right?
    07 El Bee Zee
  7. #17
    Jan 2006
    Yes. More or less, a given HP requirement (or drag total) requires the same fuel volume.
    The actual fuel volume is best defined by fuel pulse multiplied by the pressure square root. Don't get too hung up on "mm3" as illustrated in the tables. It would be best considered a unitless index.
  8. #18
    Jan 2008
    Quote Originally Posted by LBZoom View Post
    As posted by Michael earlier there is no need to alter the pulse width table when lowering or raising the pressure you are automatically increasing or decreasing the PW. you cant expect to run @ 65 mph and have a pressure of 60Mpa and a PW or 800 and then change the pressure to 70Mpa and have the same PW. you would be creating more power than is required to move the truck down the road @65. so just leave the PW alone.
  9. #19
    Jun 2008
    I've already noticed a slight difference in my economy with the lower pressure.... Why exactly does lower pressure improve MPG's if the fuel volume essentially remains static? Just curious...
  10. #20
    Jan 2008
    you are playing with how the fuel burns. either short and quick with a fast pressure spike or a slow burn with a slow rolling pressure curve.
  1. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  2. How to restore actual fuel rail pressure button?
    Last Post: November 24th, 2009, 04:59 PM
  3. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  4. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
