Results 1 to 10 of 10
Thread: What will happen?
    Dec 2009
    Default What will happen?
    I have an 07 LBZ and after doing a lot of reading found that the TCM in the early 06 LBZs has a different OS than the mid 06-07. I have access to 3 trucks and was able to switch TCMs between my work truck(bone stock) and my 07(modified and tuned). I never programmed my 07 TCM but now I would like to programm the TCM i currently have.
    My question is this; will I use up my second Vin licence by doing this because the VIN it brings up is different than my original TCM even though I never "married" my original TCM?
    ferramento, welcome the forum...
    The license is married to the controller's serial number... not the VIN.
    Each TCM you flash will require a separate license.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Each VIN license allows you to one one ECM/PCM AND one TCM. Also, you will not be able to change the OS in the TCM with EFILive. You're stuck with the OS in it unless you use a Tech2 to change it.
    Dec 2009
    Thanks a lot for your help. The reason I traded the TCM was because of what I have read on this forum and others about the differences between the two and the inability to do a full re-flash on the 6 speed TCMs. Now I have the OS that I want and don't need to do a full flash.
    Thanks for welcoming me to the forum. It is my first post here but I have spend hours on end reading all the great information that is posted here. I have only been working with my EFI Live since Christmas so I am new but learning a lot.
    Mar 2009
    Quote Originally Posted by Cougar281 View Post
    I'm pretty sure it is one PCM OR one ECM/TCM combo.
    I think it actually works as each license works for 1 ECM or PCM AND 1 TCM. I know I have 6 available TCM licenses even though Ive tuned 7 trucks (6 PCMs and 1 ECM/TCM). Havent tried licensing just another TCM, dont have a reason to.
    From the tunetool if you go Help->FlashScan V2 VIN Licensing you will see on the RHS how
    each "license" line has two fields (one for engine controller, one for trans controller)...
    each line (consisting of two fields) equals one license.
    Sep 2007
    One licence allows you to tune the ECM & the TCM
    jct, welcome to the forum...
    Sep 2007
    Thanks, After two years and seven months I have made my first post
  1. why does this happen alot? -log reading prob
    By whackem04 in forum General
    Last Post: December 29th, 2009, 03:24 PM
