Results 1 to 5 of 5
Thread: Full OS and calibration flash required for Lean Cruise?
    Mar 2007
    Default Full OS and calibration flash required for Lean Cruise?
    I am working on an '01 K2500 with a 6L and 4L80E (OS 12208322). I have added the lean cruise CAX files and copied the parameters from an '01 Holden tune that I got off of Holden Crazy. Unfortunately, so far, it doesn't seem to work. I have only done a calibration flash after making these changes. Do I need to do an OS and calibration flash instead?
    Senior Member acomp917's Avatar
    Jan 2010
    Yep,
    A full flash will enable it. If you want proof it: Flash pcm then read it(it won't be enabled). Full flash pcm and do same. It will now show as enabled.
    I got a little nervous and lowered the leanest spikes to the more average value of 1.2???. Still runs @16+AFR
    S
    Mar 2007
    Thanks for the help. BTW, does this mean that I have to do a full flash each time that I want to play with the LC settings? Or is the enable just in another portion of the code, while all the table values are in the calibration part?
    Oct 2006
    Quote Originally Posted by turbo_bu View Post
    The enable is in another portion of the code. Once enabled a cal only flash is necessary.
    The Tremor at AIR
    Mar 2007
    Thanks for the help guys. Did the full flash, kicks in like a charm
  1. Lean cruise tip-in
    By LinearX in forum Tuning For Economy
    Last Post: February 28th, 2010, 01:52 AM
  2. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 11:43 AM
  3. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 12:44 PM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
  5. Lean Cruise - US - LQ4 6.0L - Anyone done it?
    By Zfreak in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2007, 10:58 AM
