Results 1 to 5 of 5
Thread: Defuel affect
    Member SGFastMax's Avatar
    Apr 2009
    Default Defuel affect
    im running 110hp over tune on and lb7 and its not defueling quick enough during the part throttle shifts only in the 2000-2300 range, especially when shifting from 2-3 it revs just a little during the shift. correct me if im wrong could i fix this prob if i lower the torque limit value during the mid RPM range in the TLIQ table?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    If it revs during the shift it's commanding too much fuel due to the values in your base torque table, maybe TBIQ but probably not. The base torque table probably, it's the one that the engine references to determine what amount of torque to de-fuel to on the shift. I had a similar problem on an LB7. Hope this helps.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Apr 2009
    i figured one of the two.
    Apr 2009
    ok, i modified the base torque table. i took a good 250 ft pounds off the whole table and no change at all. the origional peak torque in this table that came in this tune was about 400ft pounds. the peak in the stock lb7 tune peaks at 500+. i tried putting the stock base table in because the TLIQ table is the same as the stock one in the stock tune and those have to be close to each other to correspond and i just got worse. what is going on? am i missing anything?
    Apr 2009
    figured out the problem, the dsp5 switch voltage settings were too low and causing glitches.
  1. Does the MAFSensor have any affect to starting conditions?
    By onegonewild in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2010, 05:46 PM
  2. Why does changing VVT settings affect Shifting of an A6?
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 16th, 2009, 03:00 PM
  3. L.t.f.t closer to 0 affect gas milage?
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 1st, 2009, 09:19 AM
  4. Which tables don't affect DIC calcs
    By Wasted Income in forum Duramax LLY
    Last Post: April 6th, 2006, 01:42 PM
  5. Does disabling one NBO2 affect tuning
    By hpcubed in forum General
    Last Post: July 18th, 2005, 01:58 PM
