Results 1 to 10 of 20
Thread: Problems with B1501 set to 'Disable'
    Junior Member jpgmtech's Avatar
    Mar 2007
    Default Problems with B1501 set to 'Disable'
    Hi All!
    Just spend the better part of a couple of weeks isolating a real hair-puller. This applies to trucks running OS 12628954, affects LMM's from 2007-2010 (verified)
    Condition: Setting 1501 EGR Control to 'Disable' has the following effects which seem to manifest themselves after the engine is warmed up or after a prescribed run-time:
    • Injection timing surge
    • Turbo pressure and vane surge, both on cruise and acceleration
    • Intermittent extremely black smoke on shifts (suspect this is the EGR valve physically opening even though my logs do not show it.)
    • Intermittent lag on acceleration
    What appears to happen is the turbo and injection timing modes seem to cycle back and forth with some kind of phantom EGR mode, causing the surging and intermittent black smoke.
    I have several logs that capture the surging condition if anyone wishes to look at them. Originally I backdated a few trucks to one of my older tunes until I had the time to isolate this. I just finished A-B-A testing on two different trucks. I have only used B1501 recently, most of my LMM tunes disable the EGR with the original methods - setting B1502-1506.
    Bottom line - leaving B1501 in stock position 'Enable' will solve a number of phantom problems with LMM tuning.
    Last edited by jpgmtech; February 22nd, 2010 at 08:09 AM. Reason: improve accuracy
    Mar 2007
    Yep, you have to go through and set the EGR parameters to these:
    I set all EGR flow data in tables 1526, 1527, 1528 to "0."
    B1501 Enable
    B1502 -100.000000
    B1503 320.000000
    B1504 -57.932176
    B1505 -2.900000
    B1506 -100.000000
    B1520 300.951932
    B1521 302.000000
    B1522 300.951932
    B1523 302.000000
    B1524 -57.932176
    B1525 302.000000
    B1529 6000.000000
    B1530 5999.000000
    B1531 284.000000
    2007.5 RCLB 4x4 WT LMM 8594OS
    Jan 2006
    A big high 5 Joel!
    Custom Tuning Services
    Mar 2007
    Hoping it saves some grief. I've noticed in other forums that a few guys have been setting B1501 to 'disable'. In one post, the guy noted that his tune had a couple of glitches much like the symptoms I described.
    Had at least two guys up here wondering if I knew what I was doing when I had to take a few hours on their trucks instead of the usual 30 minutes. Not good for my customer base to see glitches like that, it hurts their confidence. Still, they are happy with the results!
    Mar 2007
    Quote Originally Posted by jpgmtech View Post
    Ya no shit.
    Jan 2006
    B1526-B1528 do not appear to function either, if I understand them. Are they suppose to stop egr opening when set to 0? I see no difference after entering all zeros.
    Feb 2007
    I've not experienced any of the problems you state by setting that table to disable with that OS. Were you doing that in addition to changing the other tables, or were you trying to disable the EGR with just that enable/disable button?
    Mar 2007
    Quote Originally Posted by JoshH View Post
    I had set B1502-B1506 to disable EGR function originally, and the tunes I had problems with; I additionally set B1501 to Disable. I had in mind to shut down the EGR cleaning cycle that occurs after engine shut down, and that did fix that but introduced all of the above problems. I'm still cleaning up the odd truck that had B1501 set to Disable up here, including one today.
    It could be that simply changing B1501 to Disable without changing any other parameters might be sufficient and may not demonstrate the problems listed above.
    Mar 2007
    Quote Originally Posted by killerbee View Post
    I can honestly say I never have touched those parameters to even know.
    Feb 2007
    Hmmm, weird. I have done exactly what you said, and never experienced those problems. I have tried setting just the enable/disable to disable, but that doesn't disable the EGR (or at least it didn't for me).
  1. E38 VATS will not disable
    By v8vegaman in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2010, 03:29 PM
  2. Disable EGR?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 2nd, 2009, 03:46 PM
  3. B1501, had it now it's gone!
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 20th, 2009, 09:53 AM
  4. Disable DTC's
    By Pusher in forum Duramax LB7
    Last Post: April 2nd, 2008, 02:24 PM
  5. B1501 Low Oil Pressure Warning
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2006, 10:42 AM
