Results 1 to 5 of 5
Thread: E67 GMPP dies on decel
    Junior Member pandreas's Avatar
    Apr 2007
    Default E67 GMPP dies on decel
    Hi Guys! I've got an issue with a GMPP E67 on a crate engine that dies upon decel. The idle tables seem a little crazy on this thing! I have dabbled a little with the hi/low rpm spark correction, and B1844 and B1845 intrigal and proportional steps. I had a little success for a bit but ended up with a hanging throttle or dying on decel to idle with small changes. Anyway, need help! no sense droning on!
    Apr 2007
    Here is the stock tune.
    Lifetime Member hymey's Avatar
    Jan 2008
    B1845, maybe reduce to -.8 in the -256 cell its too aggressive, also min idle airflow, value decreases as rpm in rises in some places. I would also set the timing values in the idle and coast down flat across the board, also do this in the min idle airflow, till you get it working 100% right then you can massage those tables. I strongly have a feeling that you got the timing right, but your min idle airflow table is wrong, looks like its been smoothed in some spots, how come in N its 10 and first gear 6? these should be the same or close. So really Im not sure with what min idle airflow you ended up with? Also with coast down spark its at 10 degrees, as rpms drop so does the timing in coast down but it continues to really to reduce timing and ends up in the negatives and not recovering effectively then the problem starts, combine this with incorrect airflow tables and disaster strikes. You have to keep it simple when you are working it out otherwise it will end up bad believe me
    I will alter it for you to give you an idea and somewhere to work from. Whats your email address?
    Joel
    I have just tried to alter your tune, I get access denied trying to save it, lately had lots of little errors with efilive
    But overall run a flat timing table for idle and coast till u get it right same as min idle airflow run the same the taper is way to high, Basically you need to start again.
    Try and send me the tune to my email again
    Joel
    Jan 2008
    OK just went right through it,
    I have some questions some parameters are altered to much and contribute to the problem.
    How come, Max idle area 1 is set so low, 0.076? and Max idle area 2 at 23.xx? Did you log or just guess these settings? They are a long way out. Also b1650 for area of ETC is only 40? This setting has to be factory at 4725? Did you change this is was it like that in a tune you were supplied.
    Your max idle area 1 and 2 can be just left the same whilst setting up i would start at 1.100 at both of these.
    Jan 2008
    Pete I sent you an email of a base test idle tune to start again, send me some logs of it and I will go through it with you.
    Joel
  1. E67 GMPP controller checksum error
    By xtreme in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 03:50 PM
  2. LS2 with GMPP E67 - advice needed
    By V8RX7 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 3rd, 2009, 12:20 AM
  3. GMPP E67 missing pids??
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2008, 08:44 PM
  4. GMPP Gen-IV controller kit
    By PSWired in forum Gen IV V8 Specific
    Last Post: April 18th, 2008, 01:50 PM
  5. Need help tuning gmpp intake w/ accel 1150cfm tb
    By wadesns in forum Gen III V8 Specific
    Last Post: July 13th, 2007, 04:25 AM
