Results 1 to 10 of 10
Thread: Some help with a tune
    Nov 2008
    Default Some help with a tune
    My old man has a v6 4.3 03 silverado with exhaust and an intake. I have a v2 that I use for my duramax but I don't have any idea how to tune. He justed wanted a little extra power and I was wondering if anyone here can help. Thanks for any help that can be shared with me.
    Jul 2008
    Well, you probably just need to take some basic steps in order to learn.
    First, what kind of tuning software do you have? Do you have a wideband to measure AFR?
    A basic tune will require good O2 sensors, and no exhaust leaks. You will need to log all the basic parameters like spark, fuel, etc. A lot of that information is in the 'stickies'. They will help guide you.
    If you can successfully log, then post your results on this forum. People will then be able to help you even more.
    Hope that helps. Just give us some more information, and we can help.
    Good luck.
    Nov 2008
    Good luck.
    Thanks, but to be honest I would rather find someone that already made a basic tune for this engine and of course nothing for free.
    Jul 2008
    I do not know EFILive's policy on mentioning other sites, but there are a bunch of stock and modified tunes available online.
    Do I think it is smart to totally 'plagiarize' a tune..I might do it for a completely stock vehicle, but there is no way I would load up someones modified tune. It is risky, because every car is different.
    Let me ask you directly. Do you have tuning software, or are you just looking for a tune (free)? I am not judging you, just curious. It makes a difference in how we answer your questions.
    Thanks..
    Nov 2008
    Thanks..
    I am not someone looking for anything free like I said above. I found several people that will do tuning but they have different hardware not efilive. I'm a regular guy with no knowledge of tuning nor intentions of selling anything. Just looking for a time perhaps like a stock tune with minor teeeks. I do have all the hardware from efilive which I purchased it for my GMC sierra 2500hd with a duramax diesel engine. The tuning for it were emailed to me by someone that is a efilive vendor but he doesn't mess with gas engines. Hope this better expalains my need
    Jul 2008
    No, I understand. All the tunes posted on the "Holden" site are free. You just have to have the software.
    What I was asking is are you going to do any logging on the vehicle at all. How will you know if the tune you loaded is good.
    Again, not judging. I appreciate your honesty. But there are plenty of free tunes on the site I mentioned.
    People will help you here. Sometimes having a tune log and describing the problem will help.
    Good luck..
    Aug 2008
    Post up your Stock tune... This section(Vortec V6/V8) you posted in is for the 1998-2000 Black Box PCM. I'm pretty sure you have an LS style PCM.
    You should post in the GEN 3 V8 specific & 2001 + Vortec V6-V8
    FLASHSCAN V2 & AUTOCAL
    You do indeed have an LS1 style PCM for an 03 4.3.
    If you are looking for a solid mail-order tune that you can change around, look up Jesse at Wait4Me Performance or Alvin/Brian at PCM4Less. Just 2 options, not sure what they'd charge for a 4.3L tune.
    Nov 2008
    Ok guys, thanks for the help. I will try and find him and see what I come up with.
    Nov 2008
    Quote Originally Posted by GAMEOVER View Post
    Darn, your right I didn't notice lol. I guess I'll repost it or it can get moved.
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
