Getting this error
Error code: ERR_NOCABLE/31
No interface cable found.
What is wrong? I used the interface cable with LS1edit and it worked but I try to scan and log and I get an error message
Elmer
Getting this error
Elmer
Error data
Error report generated by EFILive at 15:59:43 on Nov 11, 2005
EFILive Version: 7.3.0 (Build 303)
Platform: Windows XP
Version: 5.1 (build 2600)
Processor type: Pentium 869MHz
Directories
Temporary Cache: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Temporary cache
Logged Data: \\Eboggs\My Documents\EFILive\V7\Logged data
Customers: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Customers
Configuration: C:\Program Files\EFILive\V7\Configuration
Exported Data: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Exported data
Images: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Images
Sounds: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Sounds
Maps: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Maps
Pids: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\PIDs
Virtual Dash: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\VDash
Print Reports: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Print reports
Bug Reports: C:\Documents and Settings\Elmer Boggs\My Documents\EFILive\V7\Bug reports
Connected: No
Com port: 0
Com setup:
Requested baud rate: 115200
Cable id: 0
Cable code:
Cable desc:
Cable version:
Cable Firmware date:
Cable model:
Cable Serial number:
Protocols: 0
Protocol list:
Auto connect: No
Scan OBDII info: No
Error retries: 1
Retry delay: 10
Message throttle: 0
Most recently used VIN: 2G1FP22G0W2xxxxxx (Note: 1)
PCM information
PCM HDW Number: Unknown
Calibration ID: Unknown
Serial Number: Unknown
Operating System: Unknown
Engine Calibration: Unknown
Engine Diagnostics: Unknown
Transmission Calibration: Unknown
Transmission Diagnostics: Unknown
Fuel System: Unknown
System: Unknown
Speedometer: Unknown
Operating System BCC: Unknown
5x24 scan mode: Unknown
10x24 scan mode: Unknown
Maximum dynamic packets: Unknown
Detected modules:
$10=Powertrain Control Module (PCM)
Selected parameters:
Most recent communication with vehicle:
15:51:56.468 Send: $01,$02,$23,$01,$00,$27
15:51:56.678 Send: $01,$01,$02,$00,$04
15:51:56.889 Send: $01,$02,$23,$01,$00,$27
15:51:57.099 Send: $01,$01,$02,$00,$04
15:51:57.620 Send: $01,$02,$23,$01,$00,$27
15:51:57.850 Send: $01,$01,$02,$00,$04
15:51:58.060 Send: $01,$02,$23,$01,$00,$27
15:51:58.271 Send: $01,$01,$02,$00,$04
15:51:58.641 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
15:51:58.771 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
15:51:59.442 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
15:51:59.572 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
15:59:40.435 Send: $01,$02,$23,$01,$00,$27
15:59:40.645 Send: $01,$01,$02,$00,$04
15:59:40.856 Send: $01,$02,$23,$01,$00,$27
15:59:41.066 Send: $01,$01,$02,$00,$04
15:59:41.487 Send: $01,$02,$23,$01,$00,$27
15:59:41.697 Send: $01,$01,$02,$00,$04
15:59:41.907 Send: $01,$02,$23,$01,$00,$27
15:59:42.118 Send: $01,$01,$02,$00,$04
15:59:42.448 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
15:59:42.588 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
15:59:43.129 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
15:59:43.259 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
Report ID: 248826 (Note: 2)
Notes:
(1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
(2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
Are the drivers installed for the cable? When you go to control panel / system/ hardware, is anything showing not installed correctly?
Is the light on the unit itself flashing when you install it into the port?
The cable worked perfectly when I fired up ls1edit and programmed my PCM today
After the programming, I was going to record while I drove home from the shop. I got the error.
The cable has a single flashing red light when the PC is running, the car is running and the cable is hooked up.
There are no error messages in the "System" Devices.
You may have the scan tool set to look for an AutoTap cable. Open the Properties window and make sure the [Connection] tab page is set up like the image.
It was looking for Atap I changed it to what you requested and still get the error message.
A red LED flashing should only occur while data is being logged - it's the heartbeat signal that keeps the PCM sending data - it should flash about every 2 seconds. However, if you have not got a successful connection then the red LED should not be flashing.
The yellow OBD LED should flash all the time that it is connected to the vehicle with the ignition on. That yellow LED shows class-2 bus activity.
In the error report you posted:
Those messages are exclusively trying to contact an AutoTap cable.Most recent communication with vehicle:
You should be seeing messages of the form:
i.e. they should start with $A1 = transmit and $B1 = recieve. If you are not seeing any messages starting with $A1 then the Scan Tool software is not even attempting to contact the FlashScan cable. That points to a configuration issue with the Scan Tool software.Most recent communication with vehicle:
12:20:32.515 Send: $A1,$23,$00,$01,$00,$C5
12:20:32.515 Recv: $B1,$A3,$00,$00,$54
12:20:32.515 Send: $A1,$40,$00,$06,$0C,$6C,$10,$F1,$2A,$00,$8A
12:20:32.625 Send: $A1,$23,$00,$01,$00,$C5
12:20:32.625 Recv: $B1,$A3,$00,$00,$54
To see those messages, just press Ctrl+G after attempting to connect to the FlashScan cable.
You could always try checking the box "Scan all cable types" to see if EFILive can automatically figure out the FlashScan connection.
Error report generated by EFILive at 18:38:05 on Nov 11, 2005
Processor type: Pentium 879MHz
Directories
Connected: No
Com port: 0
Com setup:
Cable id: 0
Cable code:
Cable desc:
Cable version:
Cable model:
Protocols: 0
Protocol list:
Auto connect: Yes
Scan OBDII info: No
Error retries: 1
Retry delay: 10
Message throttle: 0
PCM information
System: Unknown
Detected modules:
18:37:58.268 Send: $01,$02,$23,$01,$00,$27
18:37:58.478 Send: $01,$01,$02,$00,$04
18:37:58.689 Send: $01,$02,$23,$01,$00,$27
18:37:58.899 Send: $01,$01,$02,$00,$04
18:37:59.320 Send: $01,$02,$23,$01,$00,$27
18:37:59.530 Send: $01,$01,$02,$00,$04
18:37:59.740 Send: $01,$02,$23,$01,$00,$27
18:37:59.951 Send: $01,$01,$02,$00,$04
18:38:00.281 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:00.391 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
18:38:00.812 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:00.922 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
18:38:01.943 Send: $01,$02,$23,$01,$00,$27
18:38:01.943 Recv: $01,$02,$23,$01,$00,$27
18:38:02.044 Send: $01,$01,$02,$00,$04
18:38:02.044 Recv: $01,$01,$02,$00,$04
18:38:02.144 Send: $01,$02,$23,$01,$00,$27
18:38:02.144 Recv: $01,$02,$23,$01,$00,$27
18:38:02.244 Send: $01,$01,$02,$00,$04
18:38:02.244 Recv: $01,$01,$02,$00,$04
18:38:03.085 Send: $01,$02,$23,$01,$00,$27
18:38:03.085 Recv: $01,$02,$23,$01,$00,$27
18:38:03.185 Send: $01,$01,$02,$00,$04
18:38:03.185 Recv: $01,$01,$02,$00,$04
18:38:03.285 Send: $01,$02,$23,$01,$00,$27
18:38:03.285 Recv: $01,$02,$23,$01,$00,$27
18:38:03.386 Send: $01,$01,$02,$00,$04
18:38:03.386 Recv: $01,$01,$02,$00,$04
18:38:04.137 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:04.137 Recv: $01,$6C,$10,$71,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:04.247 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
18:38:04.247 Recv: $01,$68,$6A,$71,$01,$00,$00,$00,$00,$00,$00,$05,$0 0,$00,$04
18:38:05.088 Send: $01,$6C,$10,$F1,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:05.088 Recv: $01,$6C,$10,$71,$2A,$00,$00,$00,$00,$00,$00,$05,$0 D,$00,$04
18:38:05.198 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
18:38:05.198 Recv: $01,$68,$6A,$71,$01,$00,$00,$00,$00,$00,$00,$05,$0 0,$00,$04
Report ID: 280920 (Note: 2)
Notes:
That's the error data AFTER I changed it to the setting that you wanted
Ok, getting right back to the initial post, you said "I used the interface cable with LS1edit and it worked". I presume you mean you used the cable with EFILive's Tuning Tool software. There is no way that FlashScan will work with LS1Edit software.Originally Posted by eboggs_jkvl
If you meant that you were using LS1Edit's cable with LS1Edit's software then that has no bearing on whether EFILive/FlashScan will work or not work.
Download the attached USB program, plug in FlashScan and run the usbview.exe program. You should see the same information for FlashScan as the attached image. If you do not then you will probably need to re-install the FlashScan USB drivers.
