Results 1 to 5 of 5
Thread: Problems with Hitachi MAF in 100 mm housing
    Member Treurentner's Avatar
    Nov 2005
    Default Problems with Hitachi MAF in 100 mm housing
    Anyone using the #12576410 or #15865791 Ls3 LS7 etc... Powrmax 100 mm Maf sensors? Any known problems?
    My Maf frequency is in the range of 600 Hz at idle (427cui) what is 300% off from the expected level, so I´m out of range - 411 PCM table starts at 1500 Hz... watch the log
    All recommendations welcome
    Kind regards
    Marco
    Nov 2005
    Default Hitachi MAF ...
    Ok - finally I can give the solution and the answer is:
    NO it will not work in boosted applications - IF...
    you have (or get) turbulent airflow.
    This may caused by an improperly installed or missplaced bypass valve or
    insufficient size of bypass valve.
    The valve (Procharger race style) was mounted before and after the intercooler to check what´s working....
    the theory:
    the bypass valve is needed to minimize parasitic loss of the supercharger in NA condition, minimize the load on the SC bearings, improve durability, prevent extrem loads on the impeller on sudden load changes (WOT - IDLE - WOT)...
    the reality:
    the bypass valve is creating highly turbulent airflow while dumping the air.
    the turbulences were transported via the ducting until the throttle blade.
    the intercooler helps to laminating the flow again
    laminating directly depends on the size and the flow resistance of the intercooler
    turbulent flow directly depends on size of the ducting in relation to size of the dump valve
    a dump valve after the intercooler produces heavy turbulent airflow, especialy on a dual intercooler setup
    the solution:
    EASY :-) use SD tune...
    if not SD - in case you want a daily driver in all wether an environment conditions
    or you need to meassure the load (tranny pressure calculation) instead of estimating
    do NOT use a Hitachi MAF hot film sensor style...
    use the heatwire (old) style sensors like Granatell, LS6 etc... only.
    Use an SSQV bypass valve instead of the dump valve (that is closed at idle and much less turbulent flow exists.
    Have a strait duct passage 2 feet before and after the Hitachi MAF
    Do not place this sensor just before or after a bow.
    Place your dump valve ALLWAYS befor the intercooler and use a single cooler (much bigger piece) system only.
    Use a small 2." ducting only and no F-Series Procharger (just kidding :-))
    I hope this helps the guys that have
    rough untuneable idle
    non idle to light throttle transition
    heavy starting engine with lean condition on startup
    on MAF- cars in the 1k hp range...
    Marco
    Marco,
    Very good and interesting observations and explanations... thanks for updating.
    Do you have any MAF logs with bypass valve relocated before intercooler...?
    Oct 2003
    I am not sure I understand where the MAF is in the intake stream?
    If you can put it in the "draw through" path, that is- next after the intake air cleaner that would be your best option. It should be fine there for > 750 hp.
    Maybe I don't fully understand the configuration you describe but it sounds like you have the bypass valve dumping before the MAF?
    Bruce@Powrmax,com
    www.Powrmax.com
    Quote Originally Posted by Treurentner View Post
    the theory:
    the reality:
    the solution:
    Marco
    PowrMax Performance
    100 mm PowrMAF
    Post pics.
  1. Help problems......
    By VACARELLAB in forum Duramax LB7
    Last Post: April 14th, 2009, 12:16 AM
  2. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 05:27 AM
  3. lc1 problems
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 07:39 AM
  4. HELP PLEASE - problems with 7.4 & SSR
    By Boost in forum Gen IV V8 Specific
    Last Post: April 11th, 2007, 01:40 PM
