Results 1 to 10 of 13
Thread: can someone help me understand this log?
    Member badls1's Avatar
    Dec 2009
    Default can someone help me understand this log?
    hey guy, im really new to the whole tuning thing but i want to learn how to do it. so far i've been trying to read the stickys but i really dont know where to start at all. i did some logging a couple of days ago but im not to sure that i had the correct pid's. i was a little scared to get on it to much b/c im not sure how my tune is. if anyone on here would point my in the right direction with modifying my current tune, i would greatly appreciate it. and are there any good tuning books that i can get, that are more towards efilive instead of hptuners.
    thanks.
    here is my tune and log
    1989 Notch l Forged 5.3L l PT91.5 l th400
    SBE 4.8L l S475 l th400 8.62@156 (old setup)
    Oct 2006
    You have selected way too many pids. Keep the channel count under 24.
    What pids you log depends on what part of the tune you wish to work on. Let us know where you want to start & we will give you an idea of which pids to log.
    The Tremor at AIR
    Dec 2009
    where do you suggest i start at?
    Oct 2006
    I would start with.
    ECT
    IAT
    RPM
    MAP
    AFR
    TP
    MAF
    O2 sensor voltage(both banks)
    KR
    Spark advance cyl 1
    Then if something needs to be worked on from that log you can tighten the pids into that area.
    The Tremor at AIR
    Dec 2009
    okay, thanks. i will do anther log with them pid's and post up
    Oct 2006
    If you have enough channels left also log your STFT & LTFT. If only enough for one pick LTFT.
    The Tremor at AIR
    I took the list of pids that 5.7ute said and added a few:
    RPM
    AFR
    DYNCYLAIR
    IBPW1
    IBPW2
    MAF
    MAP
    TP
    SPARKADV
    KR
    LONGFT1
    LONGFT2
    SHRTFT1
    SHRTFT2
    HO2S11
    HO2S21
    VSS
    That should bring you to 23 channels.
    Also, in the scantool, go Edit->Properties->Logging->Scan Mode and select Stream-Fast.
    You are aware you have some DTC's present...?
    More reading: follow the links in my sig.
    Senior Member acomp917's Avatar
    Jan 2010
    Badls1,
    Diagnostic trouble codes.
    Take a look through the links in my signature. The SSpdDmon stuff is an alternate tuning method. Not well accepted... yet.
    In personal are a bunch of files, not well organized. There is a ton of easily accessed info in there. I was new to this system ~1month ago.
    S
    Dec 2009
    thanks, i just looked it up and gound them. i will scan my car and then check your codes are see what i can find. thank you. btw you learned how to tune in a month?
  1. I did a nice logg and trying to understand it.
    By lilicedout24 in forum Gen III V8 Specific
    Last Post: February 23rd, 2010, 02:45 PM
  2. Help me understand spark timing
    By gpr in forum Gen III V8 Specific
    Last Post: September 16th, 2009, 06:09 AM
  3. Replies: 5
    Last Post: March 26th, 2009, 02:06 AM
  4. Help understand B2226
    By 06bowtie_guy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 20th, 2007, 06:28 AM
  5. Please help me understand the autotune etc.
    By kenkaru in forum Petrol / Gas
    Last Post: October 8th, 2006, 02:34 AM
