Is the 0411 swap only for 1998-2000 Black Box PCM's or will the swap work for 1996-1997 Black Box PCM's as well? 4.3ltr-5ltr-5.7ltr-7.4ltr
FLASHSCAN V2 & AUTOCAL
It will work for the 96+97 as well. The wiring files are different also.
Jeff
I've got a question on the 96-97 Black Box Pcm's, what is the small white plug for? The 1998-2000 Black Box PCM has 4 connector's and I noticed on older 96-97 trucks they have 5 connector's....
I honestly don't know what it is there for. If you untape the harness, you will see that it is just a big loop of wire. It is not used with the 0411 PCM.
Jeff
Can Somebody tell me what all is different on the 97?
