Results 11 to 20 of 26
Thread: Searched with no luck, $0183 & $0185
  1. #11
    Apr 2008
    Seen your post over at Diesel Place forums too so post the same over there.
    So what version of V7.5 and V8 do you have installed?
    What is the current firmware and bootblock on the Flashscan V2?
    One last thing. What year is your LLY? If 2006 using the Bosch ECM then you cannot change DSP from the Flashscan v2.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  2. #12
    Apr 2008
    Nevermind on the 2006 LLy since I see you use 2005 in your username here.
    Brian
  3. #13
    Feb 2010
    05LLYM, welcome to the forum...
    So you're at builds 106 and 86...? And you installed firmware 2.6.26...?
    Load the files Options.txt and Settings.dat from S&T and not from EE.
    I will be updating my soft/firmware in the next hour or so and will try again.
    But like i've had issues before, what if I run into the "Bad Token" thing again when updating?
  4. #14
    Feb 2010
    Quote Originally Posted by Tordne View Post
    Just to be clear as well there are two filesystems:
    - Data
    - Config
    If you go into EFILive Explorer you'll notice that there is a format option on both the Data Files and Config Files tabs. Which one are you getting the error with?
    Maybe it's because my software isn't up to date, but I do not see a data files tab to format in Explorer. I will be updating shortly, no Internet on the road.
    Will this issue have any affect on me loading up a different tune like I would normally?
  5. #15
    Apr 2008
    No idea on that if safe to upload. May depend on how mixed up some things may be.
    Brian
  6. #16
    Nov 2006
    Re-download the update and re-install it.
    It may be from a bad download or maybe your V2 was a Gameboy in another life.
    LC-1 WBO2
  7. #17
    Feb 2010
    Ok, I was able to get the V8 and the V7.5 to update fine. Now, I just cant seem to figure out how to update the Firmware.
    BootBlock: 2.06.02
    Firmware: 2.06.23
    I am not up to date correct?
  8. #18
    Nov 2006
    Opening scan&tune with the V2 plugged in you should get a notice that there is a newer FW and to update.
    LC-1 WBO2
  9. #19
    Feb 2010
    Quote Originally Posted by mr.prick View Post
    Nope. Not getting anything. Anyway I can manually do it?
  10. #20
    Nov 2006
    EE> FW Tab> Browse> Select FW> Program
    LC-1 WBO2
  1. Error: $0185
    By gpr in forum Gen III V8 Specific
    Last Post: September 18th, 2009, 09:39 AM
  2. idle question with TH350...yes i have searched
    By acrider2 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2009, 04:43 PM
  3. AutoVE BBL...No luck
    By samh_08 in forum Black Box Logging
    Last Post: June 10th, 2009, 05:03 AM
  4. error $0183 and $0185
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 04:39 PM
