I just got around to updating my V2 to firmware 2.06.26 along with build 106 & 86 for version 7 & 8. I just read my two spare PCMs with my bench harness and the Black Box Read fails. I get a checksum error when I open with Tune and the file size is bigger than the last BBR 514kb vs. 470 kb with a PCM read. I had a problem reading these PCMs prior to firmware 2.06.21 which fixed the problem. I don't remrmber if I've tried to read them since then.
I reformatted the 'Config Data' using EE and reformatted the 'Internal Memory ' & SD card with the V2. I programmed the V2 using the Scan & Tune program and my 'Options.txt' file.
I emailed the read files to support yesterday.
