I just installed windows 7 and having trouble with driver sofware. Is it because I switched from vista?
8.7 @ 84 (1/8 mile) bolt-ons
I upgraded from vista to windows 7 haven't had any problems, did ya try reinstalling drivers or it won't?
2005 chevy silverado, duramax tuned with efilive
1997 Saturn sc2 turbo, tuned with megasquirt on e85
2000 s-10 turbo'd tuned with efilive on e85
To load drivers:
- Connect FlashScan to your laptop.
- Right-click on the ‘My Computer’ icon and select the ‘Manage’ option’.
- In the left hand tree select ‘Device Manager’.
- If the drivers are loaded you should see a device with ‘FlashScan’ in the name under the ‘Universal Serial Bus controllers’ section. If not it will be listed as an ‘Unknown Device’.
- If it is shown as ‘Unknown Device’ right-click on the ‘Unknown Device’ and select the ‘Update Driver Software’ option. The drivers are located in the ‘C:\Program Files\EFILive\Drivers\EFILive\Win-2K-XP-Vista’ folder, so choose
the ‘Browse my computer’ or advanced options and select this location to search. Don't go another level into the 'i368' or 'amd64' folders.
Andrew
EFILive Crew
Thank you Andrew, fixed !!!
