oh. thanks to who ever added in the self cleaning parameters to the t43 cal too as i have a large trans cooler it's take a long time for my car to reach the default 70c temp setting. i can now drop it down and perform the test.
Hopefully this makes sense in general terms...
Adaptive learn is intended to normalize the trans physical state so that the electronics can control it consistently. i.e. either through factory tolerance stack up or wear and tear over time the dimensions of the clutches, both the fibre line and the metal plates change, as do ports/orifices in hydraulic components.
Learn factors ensure that these changes or differences always look the same to the electronic calibration/operation and that over 100,000 miles or more, provided the wear has not exceeded the compensation limits that learn provides the TCM will compensate for wear by correcting the calibration parameters with the learn factors and then piston fill rates/volumes for clutch operation are adjusted by the stored learn factors.
Adapts reset clears adapts to "zero"
Adapts preset sets adapts to a pre-calibrated factor that the factory worked out for a new trans.
Fast learn runs the built in learn sequence while standing still in a workshop so that a 50km drive is not needed.
Fast reset - faster version of adapts reset? Or maybe a TCM reboot. Not mentioned in any service docs .
LOL yes. They finally figured out after 3 - 4 years of A6 trans's that a seal was faulty or badly installed on some (a lot?) trans's.
On the 08 6L90E I run there arent any flare issues. Very lucky I woul say. Have not changed the 2 > 3 Max Adapt Shift Volume. Still stock at 40. Though this is the same on all A6's normally from the factory at 40 as Patrick G pointed out, GM did change it to 50 for the CTS-V 6L90E. Some people change it to 200 and claim a difference. Maybe it does help with the flare issue due to the bad seal. My understanding of these numbers is that they are simply limits for the adapt compensation. The 2 > 3 shift uses 2 oncoming clutch sets and one offgoing so the number is not about a single clutch, and all the pistons have different fill amounts which are nowhere near 200cc even if they are dead empty which they are not. Lucky if they exceed 100cc on the larger diameter clutches like the 1-2-3-4 clutch.
The explanations put forth for Adaptive Learning (while informative) still didn't provide me with a full grasp as to what it does. So I went searching for more info. As taken from a Corvette site.
"Below is the actual description from Service information. Just remember, under normal circumstances, the transmission will default to second gear in certain conditions but LEARNING IS CONSTANT>
The 6L80 transmission utilizes a line pressure control system during upshifts to compensate for the normal wear of transmission components. As the apply components within the transmission wear or change over time, shift time (the time required to apply a clutch) increase or decreases. In order to compensate for these changes, the transmission control module (TCM) adjusts the pressure commands to the various PC solenoids, to maintain the originally calibrated shift timing. The automatic adjusting process is referred to as "adaptive learning" and it is used to ensure consistent shift feel plus increase transmission durability. The TCM monitors the A/T input speed sensor (ISS) and the A/T output speed sensor (OSS) during commanded shifts to determine if a shift is occurring too fast (harsh) or too slow (soft) and adjusts the corresponding pressure control (PC) solenoid signal to maintain the set shift feel.
The purpose of the adapt function is to automatically compensate the shift quality for the various vehicle shift control systems. The adapt function is a continuous process that will help to maintain optimal shift quality throughout the life of the vehicle."
Based on this definition and the highly modified tunes that I am playing with, I am finding some trends and patterns and struggling to develop a theory of its application and operation. I believe that the higher the Adaptive Learning numbers (D9500 and on) are, the more aggressively the transmission will attempt to soften shifts...felt by the end user as a delay in upshift. Obviously, lower Adaptive Learning number (D5000 and on) are, the less aggressive the transmission's attempt to soften shift..i.e.quick shifts.
How all of that convergence translates into a process that can explain the affects of line pressure...well I'm at a loss. Maybe by setting a higher line pressure target to reference, knowing that it takes extreme driving conditions to achieve, the transmission sees minimum clutch wear and keeps a rather minimum adjustment of clutches engagement. Conversely, by setting lower line pressure targets means more rapid clutch wear and and therefore constant adjustments to the clutches engagements. Perhaps at this point it refers to other T43 settings, which being vehicle specific, may be set up for lazy/clutch protecting shifts based on engine load, vehicle speed and TPS. Or maybe it adjusts all/some other T43 shift settings to those Adaptive Learning line pressure targets. So the smaller the standard deviation for ALL T43 settings the more consistent the shifts will be under all driving conditions, rather than hit or miss.
At the end of the day, I think the key for any 'tuner' to understand about these transmissions is that they are EXCEPTIONALLY intelligent. And with all 'intelligence' it requires a great deal of information AND accurate application of that information. That said, all the various parameters that we tweak and adjust throughout a calibration have to be considered within the context of the entire calibration. In other words, making an XYZ adjustment to a given parameter for a 2010 Camaro may not effectively give the same results for a 2008 Escalade as the T43 looks at that particular parameter as a whole of its hundreds of other data parameters. Changes therefore need to be applied to broader methodology, rather than change this cell to this or that.
Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
