How much should LTFT vary from bank to bank before you need to start looking for air leaks in the intake or exhaust? I am looking at one that is 7 and 14. has not been tuned yet.
THANKS...
THANKS...
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
Sometimes an air leak (exhaust).
Also drivers side bank has that occasional EVAP purge..which can mess the driver-side Trim. EVAP can even mess up WOT.
Lot of little things..but 7 to 14 Trim swing is pretty large..
