Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 202
Thread: New Tuning Tutorial: WeathermanShawn
  1. #21
    Apr 2007
    Quote Originally Posted by 5.7ute View Post
    What Marcin is trying to say is if the tune was right with the old injectors, fitting larger injectors should only need the injector tables modified. Not a complete retune of the airmass tables. This would obviously come from the assumption that the old tune was correct, which DrkPhx has not stated so IMHO is not really relevant to this discussion.
    If the old tune was correct though, this opens a different can of worms that will need correcting before continuing.
    Good point. I should clarify The original tune was not correct with the old injectors. I knew this and wanted to try this method since I would be starting from scratch. My goal was to start from a stock tune with new injectors and work from there to see how fast I could get the new tune in order. Sorry for any confusion.
  2. #22
    If there's any typos or problems with the pdf or the calc_pids.txt please let us know.
  3. #23
    May 2006
    Ok, I think I have everthing ready to go, well almost. I had a little trouble making the maps, well not really trouble just had to look around a little more. Since my car is E38 I did not have B0101, so I used B0141 for the CalcVe_Table map. For the Calc.LTFTBEN map I did not have B5001 so I had to use B1099.
    The maps look right but are the values from the tables the same. My calcVE_Table map starts at -40 and goes to 216. I think this is ok since the MAF limits are higher, but just double checking.
    Darrin
    More trouble....GM.DYNAIRTMP_DMA, GM.AFR, AND GM.CYLAIR_DMA are unsupported by E38 are there different ones I can use and then change the calculated PID's?
  4. #24
    B0141 is not the right table... E38 has tables B81xx... i.e. virtual VE... I am not sure how this will work for E38 or E67.
  5. #25
    Jul 2008
    Darrin:
    I have only tried this on the LS-III OP systems. You or someone else may have to educate me on how E38 works with VE Tables, MAF, closed-loop etc.
    Can you log DYNAIRTMP.DMA?
    As Joecar said:
    Shawn means GenIII LS1 systems, more specifically 1999-2008 LS1B.
  6. #26
    May 2006
    Yeah, I am running nto more trouble, see above edited post. some of the PID's are not supported. I will keep at it with your help and see what happens.
  7. #27
  8. #28
    For E38 see here: showthread.php?t=8961
  9. #29
    May 2006
    Yeah, I am begining to think this will not work for me. I did fine the VE map B8101 now my map looks right...
  10. #30
    Jul 2008
    Sorry about that. There are so many differing types of vehicles and platforms. Hard to have a technique that can work for them all.
    For the Gen-III LS1's, it is not that hard to do. I have plugged in 4 differing tunes from 15% +/- values added to the VE Table, and differing RPM Airflow Calculations. In each case with MAF enabled, Trims are almost identical. I would have to have an expert to figure how it effects transient fueling situations.
    May not help you in your current situation, but just reassuring other users I have tested almost every combination of tunes (even throwing in bogus VE Tables) and have found as long as the MAF airflow is correct, you get very consistent results.
    It may take a few days to summarize the results..always willing to share the logs and tunes..but I think it will take more than my results to add to the credibility of the method.
    Maybe someone can figure out a method for you Darrin? Hate to leave you high and dry..
  1. How about a transmission tuning tutorial!
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 3rd, 2020, 04:53 AM
  2. Tuning Notes by WeathermanShawn
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: July 12th, 2013, 03:21 AM
  3. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  4. Idle tuning... more info on tutorial please!
    By vxleather in forum Tutorials
    Last Post: July 16th, 2008, 12:11 PM
  5. How about a transmission tuning tutorial!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2006, 04:09 AM
