HI Guys,
I have a VS V8 377ci with factory ECU modified to allow flash programming.
I can connect to the ecu with EFILive V4 but it does not display anything on the dashboard or ALDL stream.
Any info would be grealty appreciated.
Dean.
HI Guys,
Dean.
I recall (a long time ago) a discussion about ECU that had been set up for flashing would not scan/log unless some other criteria was met. Unfortunately I can't recall where I read or heard that information. You may need to contact the company responsible for doing the flash mod to your ECU.
