Results 1 to 7 of 7
Thread: 09 E38 VATS Not Working
    Dec 2007
    Default 09 E38 VATS Not Working
    After having zero trouble on 06/07/08's an 09 has stopped the show.
    Anyone managed to disable VATS on an 09 E38 12628990 Corvette OS?
    I disabled VATS via the patch as usual and full flashed but the engine wont fire. Coils turn on and injectors pulse once with key in crank position and then thats it. Subsequent starts there is no injector pulse unless the ECM is powered right off.
    Similar behavior if an 08 E38 that has NO VATS disable applied.
    Plug an 08 back in or anything else less than 09 and starts right up.
    Has VATS been proven on this OS for 09?
    Thanks anyone .
    Hi Ian,
    I've been away for the last couple of weeks, I'll squeeze this in to look at this week, I assume you still have the vehicle to test with?
    Dec 2007
    Yes the car isnt going anywhere . Its the devtest car. Rolled back to an 08. Double checking it again this morning.
    I am starting to wonder whether some OS's need to see the 12V on the powertrain relay circuit and some dont.
    Slight difference in the injector behavior with VATS enabled or disabled. Injector pulses once with VATS disabled, but not at all with VATS enabled.
    That is interesting on the injector pulse thing. Did you happen to check DTC's, maybe there is a hint there as to what is wrong?
    P.S - You just made post 555, kind of ironic given the ethanol thread.
    Dec 2007
    LOL yes! Post 555. I gotta get a life. Maybe I should buy a lottery ticket today, or go back to bed and hide! Or maybe I just feel 555 in years this morning! I thought it might be the number of months since the 555 hit the streets. But more likely when the first IC was invented . We've come a long way.
    No DTC's of any significance come up. Having the PT relay in circuit makes no difference.
    No DTC's hey, pretty much like when a patient walks in to a doctors and says "I have a problem", doctor says "what is wrong"?, patient says "guess".
    Dec 2007
    Said that to a GMPP E67 Saturday. It didnt say anything. But in the end it sure was dead.
  1. E38 VATS will not disable
    By v8vegaman in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2010, 02:29 PM
  2. E38 cant disable VATS
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: October 30th, 2009, 03:43 PM
  3. Cadillac vats ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2009, 02:41 PM
  4. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 08:56 PM
  5. 97 Corvette VATS
    By tracykeyes in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 01:33 AM
