Results 1 to 4 of 4
Thread: Extended MAF?
    Mar 2007
    Default Extended MAF?
    Saw this over on LS1Tech - something that is done with HPT's.
    "By cutting the MAF table in half and using a LS3 Sensor in a 4" Tube you QUADRUPLE the MAF limit. With the HP Tuner extended Hz Range hack you cannot peg the maf until 15000 + Hz. Which means you can control the entire fueling of the car with the MAF table. Very similar to FORD Tuning. "
    Is this already in EFILive? Is this only able to do this on a E38/E68 ECM?
    What Grams/s are you trying to achieve? My 08 E67 TBSS stock MAF table goes from -1 - 3000 Grams/s and from 0 - 15000 Hz.
    Are you trying to overcome the 512 Grams/s limit the early E38/E67s had?
    Mar 2007
    I don't necessarily have a limit on my car (using COS and LS1 PCM). Just thinking about another project car using the newer ECM's. I have done some reading on the LS3 MAF sensor and with the blade type setup some guys are putting them into different larger tubes. I know this is "not correct" but from a performance stand point, "might" be useful if one were trying to keep a MAF into boosted land.
    I did start to open up a few more tunes and noticed what you mean by the earlier limits of 512 Grams/sec. Is there a patch to "extend the range" on these ECM's?
    Quote Originally Posted by turbo_bu View Post
    Ah I see. I dont believe there is a patch to extend the range on the early E38/E67s. I think EFILive looked at it a while back when people were first running into this issue, but I believe it wasnt pursued (Not sure of EFILive's reasons. I would assume because you could just go SD and bypass the issue plus the later ECMs do not have this problem).
