Results 1 to 3 of 3
Thread: Gears in 2010 Camaro...
    Default Gears in 2010 Camaro...
    Since the speedo calculator hasn't worked right since I can remember, what is the best approach in making the correct adjustments with a manual trans?
    HO122 is for axle ratio; is this a "dumb" parameter or is weighed into the speedo calculation?
    What tables in the code are needed changes?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Solution???????
    Dec 2007
    If the Camaro is similar to the G8 the speed is probably from from the ABS system. :(
  1. Non Supported Vin 2010 Camaro SS
    By RMCR in forum Gen IV V8 Specific
    Last Post: February 10th, 2010, 10:17 AM
  2. 2010 Camaro & 150 shot
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 05:20 PM
  3. 2010 Camaro
    By jnjprfrmnc in forum E37, E38 & E67 PFI ECM's
    Last Post: October 29th, 2009, 08:06 AM
  4. 2010 camaro
    By nchristian in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2009, 10:03 AM
  5. 2010 camaro problem
    By Ls1joe in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2009, 10:32 AM
